2012 Audi A8 Steering Problem
![Unhappy](https://www.audiworld.com/forums/images/icons/icon9.gif)
Hi guys. About a week ago I noticed steering getting extremely heavy on low speeds all of a sudden. I checked the steering fluid and it was empty; however, I have not noticed any leaks. I filled the steering fluid back up, and it has not gone low since, but the steering is still very heavy.
The car is 2012 Audi A8 4.2L.
What do you guys think might be happening? Has the power steering pump gone bust?
If steering pump don't make much noise I would assume it is steering rack (I think that's the name of it) I know Q7 TDI had issues with steering racks and that's where the fluid could escape as well.
I did not change the drive mode. When I first felt it I thought someone had switched it to dynamic mode, because the sensation is quite similar, but it’s in comfort mode. And it only happens while stationary or at very low speeds. As soon as you press the gas it loosens up.
I don’t think steering pump makes any noise. Would you know how I could check if it’s the steering rack?
The best way would be visual inspection. Lift car up take belly pan covers and look for fluid leak. I know Q7 had very small leaks but fluid was escaping. You might need new steering rack.
Chris Brookes
05-16-2018 06:15 PM
Danforz
TT (Mk2) Discussion
02-27-2012 12:43 PM
