2013 A8L 4.0 Power Steering Pump Replacement
Greetings All!
Long time subscriber first time poster....
Wondering about the cost for replacing the power steering pump. I'm waiting on the estimate from my local (and trusted) independent Audi shop, but from what I have been able to ascertain I am not going to like what I hear. Apparently, the subframe has to be lowered and a motor mount has to be removed to provide sufficient access to R/R the pump. Time estimates seem to be from 8-10 hours of labor plus ~$1,200 for the pump....is this correct? I suspected the pump was the issue when I brought it in and so I did a scan beforehand (which did not indicate any electrical or ABS issues). Thoughts on the price and anything else that should be checked?
Thanks!
Thanks!
Flagship addict
Other than the price of the pump that's about correct yes.
Flagship addict
That's the full dealer price but I managed to get a pump for my W12 that costs $1600 for $85 so considering how much more common the 4.0 is I would think a similar deal can be found somewhere. It's well worth looking IMO
https://www.fcpeuro.com/products/aud...-zf-4h0145156p
And if it's a leak, be sure it isn't an attached hose, especially high pressure side. If it is stiffness, be sure it isn't rack or servotronic control (which at least used to be at rack--not sure on D4).
Hi!
That price sounds about reasonable given an average labor rate at indy shops of $120+. I wouldn't skimp on the pump, definitely buy one new, but you could also look around for OEM suppliers selling them for much cheaper than Audi. One trick I've learned is to check multiple dealerships in your area on the audi parts website...you'll be astonished at the difference in prices. I personally buy parts from Audi Shrewsbury (in Massachusetts) even though I haven't lived there for several years. They offer the cheapest parts prices BY FAR.
Check the steering rack for leaks before you replace the pump. If you're replacing the pump, you might as well also replace the rack and check all the lines. Its a "while you're there" job and those components have a similar shelf life. When I did this job on my 2008 S8, I purchased a pump from an OEM supplier and a rebuilt steering rack from Detroit Axle. They have a great warranty and the prices are fantastic.
mjrsmith1
06-30-2024 05:45 PM
Pre95
09-15-2007 11:25 AM
