When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hello all. I just picked up my 2013 S8 from my independent shop, O'hara Automotive for A/C pressure sensor failure. They called last week to inform me that there was an oil leak from what they suspect to be a rear main seal. The car is still under the Manufacturer Drive train warranty. They suggested that I take it to the dealership for the oil leak to.be repaired under warranty. I do have an extended warranty through a 3rd party company. Does anyone here have experience with a 4.0L rear main or oil leak that appears to come from that a
It appears to me that it has been leaking for some time as it has quite a bit of build up in the lower engine cover insulation and on plumbing that has attracted a thick layer of dust. It was purchased as CPO from Audi North Austin (bad experience) and I had my local Audi Dealership do an oil change at ~40k, neither of which reported the oil leak. I will attach a photo taken by my mechanic.
No experience with the rear main seal but I would take it to the dealer if you still have a warranty.
I've heard if the PVC valve and/or Venting system has issues it will cause the rear main seal to leak because the crankcase pressure builds and cannot be released thhrough the proper avenue.
I got the same leak and my mechanic told me its the same thing. For some reason I havent been losing oil lately but that area there still seems to be wet. I posted a picture of that on a separate thread a while back but never knew what it was. Unfortunately my car is out of warranty. To replace that seal will be like a all day thing if not 2 at a independent shop as my mechanic said both engine and tranny have to be dropped. About 2k labor and parts if not more so im leaving it alone for now
absolutely. Unfortunately you never know with used cars. This is my first used car and while I love the car, it sure could be a headache. I'm glad I'm not the only one. Thought it was the transmission at first
Doing the rear main seal is no joke. I remember well on my old LS430 most would replace these out of caution but not until the second water pump / timeing belt job at 200k miles. On that engine I don't think you needed to drop the transmission either.
Thanks for the replies. It is disappointing, but hopefully it will be covered either under Manufacturer drive train warranty which expires in 12/2017 if rear main seal, or by extended warranty if it the culprit is the AOS. I will update this thread as I find out more.
