2015 A8 Vibration at 3K RPM
I noticed that I seemed to be getting a vibration when I took off on a turn a little brisk... Initially I thought maybe I was having an issue with the all wheel drive accelerating around a corner, but then I checked just sitting still in neutral and the engine starts to vibrate at 3K RPM. I've got 32K on it and while I find it hard to believe that the plugs could be going bad I guess it could be a plug not firing consistently at that RPM... The power seems good and it does smooth back out at higher RPM so it would be weird that a plug would do that... Also any idea why the plugs are set to be changed at 35K?? My lexus is 100K, seems like plugs can certainly take a bit more mileage...
I need to put my monitor on it and see if I have any errors.
Thanks!
Thanks!
Moderator
Like TinyElvis alluded to, If you have the 4.0 take a gander over here... https://www.google.com/search?q=site...hrome&ie=UTF-8
Thanks everyone! I searched on 3K RPM vibration and never saw anything... maybe the RPM threw it off?? or missing the 1K. I remember seeing this on the 2014, and I thought I was safe with the 2015, I guess not. Into the dealer I go...
