ACC driving program
ACC driving program
Hello,
Does anyone know how to enable this extra menu "driving program" under ACC in MMI? Or if any of your cars have this menu enabled from the factory, could you please share your coding and adaptation channel under 13: Auto Dist. Reg? Thanks in advance.
Best regards
Best regards
I don't even have adaptive control in my MMI. I can change the distance with the ACC handle while engaged, but can't change the default from the MMI, only with VCDS.
I did have this option on my 2010 D3 (USA Car). Following.
There is a coding in Address 13 adaptation that you could change to activate the extra option for ACC distance in MMI. But I couldn’t find any coding related to the driving program menu shown in the picture.
Adaptation for default distance setting
Hello,
Best regards
Best regards
Enabling the default distance setting in the MMI for Adaptive Cruise Control
Module 13 - Auto Distance Regulation
Adaptation - Channel 07 Set to 1
Reboot the MMI - Press MENU, central MMI **** and top right softkey
Outcome - In the MMI you should now be able to go to Car > Driver Assistance > Adaptive Cruise and see a new option there to set the default adaptive cruise distance.
Enjoy!
Golan Remi (09-13-2021)
@FlyingDutchmanOK
I followed your directions, but did not have #7, instead In my VCDS the correct selection in adaptation under module 13 is "distance basic settings". I turned that on, restarted the MMI and the option was then available. Maybe we have a different VCDS version? Mine is 18.
i still can’t find how to enable the driving program, or what this option is all about.
OberklasseA8 (10-06-2022)
MCPaudiTT - DEFCON 1
07-21-2008 11:44 AM
M3KILR
11-25-2004 09:46 PM
whodkne
17
02-21-2003 11:15 PM
