Adaptive Cruise not working - ACC and Audi Brake Guard Not Available
I posted how to remove my rear bumper, and was asked by a forum member how I diagnosed the problem, so I thought I'd start a new thread, and perhaps get a DIY going on the fix.
My 2013 A8L is stock and has no history of accident -- I have owned it about 1 yr. I took a road trip this past weekend, and in the middle of it, Cruise Control and Lane Assist stopped working. When I got home I scanned w/ VCDS and found these faults:
So, I believe that the Adaptive Cruise modules are fine, but are being restricted from working correctly due to a bad lane change electronic module (Part No: 4H0 907 568 A) that is preventing the Adaptive Cruise Control from working -- Is this correct?
It appears to me that it is the drivers side module located behind the rear bumper is the one that has a defective CPU. Any one else seen this before?
So, I believe removing the rear bumper and replacing the module is the answer.
I was hoping someone else has seen this and can comment???
Code:
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb Part No SW: 4H0 907 561 B HW: 4H0 907 561 Component: ACC3 H17 0400 Serial number: 00000000000000 Coding: 7E01020101 Shop #: WSC 02313 785 00200 ASAM Dataset: EV_AdaptCruisContrAU64X 002021 ROD: EV_AdaptCruisContrAU64X_002.rod VCID: 2A0E0B9F6C79CF2753D-807E 1 Fault Found: 145152 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 109 Mileage: 89594 km Date: 2017.04.07 Time: 12:44:42 Control Module temperature: 17 °C Voltage terminal 15: 14.511 V Velocity_vehicle_reference: 31.03 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s² and this: Address 3C: Lane Change Labels: Redir Fail! Part No SW: 4H0 907 566 A HW: 4G0 907 566 Component: J769 SWA MasterH02 0040 Revision: 00H02000 Serial number: 6PZ 010 287-07 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 2E06078F5C11A3078F5-807A Subsystem 1 - Part No: 4H0 907 568 A Component: J770 SWA Slave H02 0040 Subsystem 2 - Serial number: 6PZ 010 287-27 Subsystem 3 - Serial number: 5F09.10.1200H02000AMS14105ÿ Subsystem 4 - Serial number: S14105ÿ 1 Fault Found: 16365 - Control Module - Electrical Error; CPU 2 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 109 Mileage: 0 km Time Indication: 0 Date: 2012.01.01 Time: 00:00:00 and this: Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb Part No SW: 4H0 907 541 B HW: 4H0 907 541 Component: ACC3 H17 0400 Serial number: 00000000000000 Coding: 7E01020101 Shop #: WSC 02313 785 00200 ASAM Dataset: EV_AdaptCruisContr2AU64X 002018 ROD: EV_AdaptCruisContr2AU57X_002.rod VCID: 280AF1977275FD37459-807C 1 Fault Found: 145152 - Function Restriction due to Faults in Other Modules U1113 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 109 Mileage: 89594 km Date: 2017.04.07 Time: 12:44:42 Control Module temperature: 16 °C Voltage terminal 15: 14.490 V Velocity_vehicle_reference: 30.07 m/s Longitudinal_acceleration_vehicle_reference: -0.02 m/s²
Scorpion_1011
Audi A3 / S3 / RS 3 MKII
10
03-20-2017 11:45 AM
Rocky-in-Connecticut
Q5/SQ5 MKI (8R) Discussion
05-19-2008 03:37 PM
Charlie Brown 99
13
02-11-2007 07:27 AM
Jon C
02-28-2006 09:25 AM
LeTThal
07-01-2000 08:12 AM
