When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi! I got an error message in the dashboard; Air suspension service mode: vehicle can only be moved with restrictions. do you have any idea how to deactivate service mode with OBD11 its an Audi A8 2011
witaj , pierwsze sprawdż sobie wszystkie czujniki poziomowania na każdym kole wizualnie czy nie jest uszkodzony , sprawdz vcds lub obd 11 błędy , prawdopodobnie trzeba będzie korekty zrobić na pneumatyce
Hi and thanks for the reply. I made a basic setting and through adaption I measured the wheel hub distance it was 408mm all 4 wheels +/- 3mm. The error appears when I play with output test then disappears as soon as I log out OBD11. My question to you how can I make pneumatic adjustmen with OBD11 I have no fault code on OBD11, Thaks
