When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi anyone with knowledge of Audi A8 2011 - 4.2 ltr.
the mechanic gave me a list of errors codes which I believe are due EPC light on the dash.
P200500 & P200400.
Question is this a cheap fix as I’ve received a hefty estimate and 18 days for parts and fixing.
I missed mentioning my car is 2011 hence I could not give the above suggestion a try. see below description.
I am really upset as the car did not have this issue before it went in for an oil leak change. see last attachment that shows the work that was carried out after which they advised me of the new issues with the EPC.
Yeah I don't know. If you say you just had work done it seems even more likely they forgot to attach a vacuum hose or connector somewhere.
Sadly these days you have to be able to DIY more and more, at least diagnostically, due to seemingly uncaring service.
