When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I want to use Apple Carplay in the back for. Available at the front. But I couldn't do it to the back. I'm waiting for your help.
I struggled for 1 month but could not.
Unfortunately the only available shared sources between front and rear are AM/FM and Sirius XM radio and the optional DVD changer in the glove box.
Only these media sources and be controlled by both front and rear MMI. Of course all media sources from the rear can be played through the whole car (rear Jukebox, two SD card slots and CD/DVD drive at the rear and anything plugged into the rear AMI)- however someone needs to be back there to control them.
If you are looking specifically for Apple CarPlay you would still be limited in the same way. Anything set up from the rear cannot be controlled in the front aside from volume and turning off the RSE.
