D4 codes: dial sweep & D / S gear display
![Post](https://www.audiworld.com/forums/images/icons/icon1.gif)
Still 'learning' the D4 '13 (A8L 4.0T); found out Audi does not code the car for some neat stuff, including opening all windows with remote /good for summer time/
*any one out there know the codes? I've had the car 7 weeks rolling 5500 miles; can't seem to stop driving it!
These are for my S4. Quite a few of them translated to my wife's A8.
I know the comfort opening and the gear display works.
Disable After-wipe of windscreen wipers
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
________________________________________
Disable amber corner lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
Disable Key warning (keyless models)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
Disable LED 'wink' on turn signal
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
Disable NAV & Phone warning messages while entering data at speed
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
Disable Seatbelt Chime
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
Enable Adaptive brake lights
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
Enable Ambient Interior Lighting Control
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
Enable Automatic Gear selection shown in DIS
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic Hill Hold Assist ‘lite’
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
http://www.audizine.com/forum/showth...r-the-A4/page2
Enable Auxiliary ventilation
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Enable Battery meter
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
Enable Double Disarm Beep
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
Enable DRL Selectable via MMI
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
Enable Euro parking lights that turn on signal at night
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
Enable fog lamp to come on for the same side as that turn signal
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
Enable Front Turn Signals as Parking lights
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
Enable Gauge Test/Needle Sweep
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
Enable Headlights on all the time
Bit 5 - Check the box or change
Bit 5 Set to 1)
Enable Hidden menu in MMI
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the "Bootloader"
Enable Import CDs to MMI's HD
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
Enable Independent Fogs control with high beams
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 - Check the box for "Lap Timer active"
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Enable Rear Tail Lights on with DRLs
Bit 7 - DRL's via Tail Lets Active (1 = Active)
Enable Release Parking Brake without putting foot on Brake
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
Enable Release Parking Brake without putting seatbelt
[Adaptation - 10] -> Channel 7 Set to 0
Enable Reverse mirror tilt
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
Enable Speed through MMI
[56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
Does not work if NAV equiped
Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
Enable VIM on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
Set Audi parking system - Switch OFF Speed
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
Adjust Consumption in DIS
[17 - Instruments]
[Adaptation - 10] -> Channel 3
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
Submodule 0
Reset MMI
Bit 1 – Set to 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Reset MMI
or
change 0 to 255
Add 4
Bit 5 set to 1
Enable DRL
Bit 0 - Set to 1
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
change 0 to 1
[Hidden menu]
Import Media
Enable Lap Timer
Bit 2 - Set to 1
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
Enable VIM on MMI
Set to 255
Reset MMI
[09 – Cent. Elect.]
change to e.g. 500
[09 – Cent. Elect.]
change to e.g. 10
[17 - Instruments]
DIS: 9,3 l/100 km.
DIS: 23 MPG.
Mike
I have entered most, if not all, of these and I am having issues with the following not working
Tried to get this working but still get the chime when opening the door
Still not working as I get the warning still.
Set this but haven't tested. Not sure what to do for testing. I think I need to come to a complete stop for this to work.
One would think that the flashing break lights would start as soon as you jam on the breaks but that hasn't been the case thus far.
Not even sure this will work on our A8's
Set this but it isn't working.
Set but not tested.
Bit 0 - Set to 1
Bit 0 - Set to 1
change 0 to 1
change 0 to 1
Anyone in the Boston area [or for the month of March, in the Fort Myers, Florida area], who, for a fee, has the equipment and experience with multiple prior re-works, could do a VAG-COM rework of my systems? If so, PM me.
In the meanwhile waiting to see if there is a response, what would be the average cost for this service?
Although it is a model year 2011 NWB, delivered November 2010, I only have 25K miles on the A8 as it is not my primary means of transportation. It is out of warranty...
