Dynamic pitch angle offset
2011 audi a8 4.2L
In on-board camera module, what would you describe as the pitch angle offset ? It stays at 1.324degrees and could be the issue with the cruise control
Would it be the up and down alignment of the camera? (on top of the mirror) Thoughts?
Yes I did. Also read the ssp to better understand the system. Currently the only fault that isnt a dependancy code is in image processing for no video feed . So if the camera is at fault , perhaps it cuts the feed. OR the camera is on it`s way out. Unfortunaly, no GUI to SEE what the camera sees when the system shuts off. Right to repair pls !
secreTTasianman
09-13-2005 12:44 PM
Kinetic0510
12-27-2001 01:57 PM
