Emergency (hazard) flashers turn on by themselves
![Cool](https://www.audiworld.com/forums/images/icons/icon6.gif)
I'm hoping this title will get some responses. If your car turns on the emergency flashers while you're driving, accompanied by seats moving, interior lights turning on full-bright and other strangeness, please respond.
Sounds like something to do with Pre Sense which, among other things, pretensions the seatbelt, closes sunroof and windows and turns on the hazard lights. Perhaps someone came close to rear-ending you?
No. This is definitely a malfunction of some sort. It has happened about a dozen times so far, sometimes while driving. Sometimes while stopped. When it happens, I can't turn off the emergency flashers, the car won't lock, the interior lights are on full bright and can't be dimmed or altered, and the seats move (most recently the driver's seat tried to fully recline while I was driving).
I'm pretty certain nobody was that close to me, or even behind me in most of those dozen cases. Several of them happened while there was absolutely nothing around.
Today, I couldn't lock the car for 20 minutes while all this happened. I'm extremely certain this is not expected "pre-sense" behavior. Moving the driver side seat into full recline while you're driving will CAUSE an accident, if anything.
The dealer suspects a bad driver's side seat control module, which makes sense, but is very disappointing since I began having issues before I even got to a 4 digit odometer.
New cars are so filled with electronics that I find it a minor miracle that any new car can drive off the lot without a random system failure. You just got "lucky" and would guess that, once the faulty component is replaced, you'll love your car again.
As for the timing of the failure, that actually makes sense. For electronics, most failures occur soon after the in-service date. If they make it 1,000 miles, they're probably good for at least the life of the warranty (and probably a lot longer).
The only problem is that I've been "lucky" with three Audi's in a row.
If I can get this fixed and only worry about "scheduled" maintenance for a year or two, Audi will retain my loyalty. If a month without visiting the dealer continues to be a rare event, I'll have to hold my nose and look toward the Asian manufacturers.
Did you get this fixed? If so how, my 2005 A4 cabriolet just started doing the same thing.
timshuwy
Q7 MKII Discussion
12-29-2017 12:35 AM
dreamcar2012
A4 (B8 Platform) Discussion
02-01-2017 10:49 AM
ShadowofBob
06-06-2007 08:31 PM
