Guide to removing door panel / wing mirror?
A above, does anyone have a guide to this. Some wacked my wing mirror and I need to replace it. I presume you need to remove the interior door panel.
Depends probably on whether base/metal framework is cracked, twisted or broken. If it is only the outer shell, signal marker and/or glass those are do-able with underlying mechanical assembly still on car. BTDT on various prior ones.
