Help: How to remove rear subwoofer?
Hallo,
I am doing swap from standart speakers to B&O, does anyone knows how to remove rear speaker behind the rear seats under the window? It looks like from the inside and not from the truck place.
Thank you
Thank you
Welcome to Audi World !
The rear shelf has to be removed from the interior to access the speakers.
Instructions say to remove:
- seat backrest
- armrest upper trim
- belt guides
- outer belt anchor
- D-pillar trim
- C-pillar trim
- speaker trim [Note: Speaker trim cannot be removed without destroying it.]
- 4 bolts in center
- unclip the shelf
- disengage from the shade
- pull forward and out
It may be possible to do without every step, but it sure looks complicated either way.
Not certain but you may need to swap to the B&O control module, recode and have CP removed.
If you decide to proceed I'm sure photos of the procedure would be appreciated by all.
- seat backrest
- belt guides
- outer belt anchor
- D-pillar trim
- C-pillar trim
- 4 bolts in center
- unclip the shelf
Hallo,
It is done
I have done also protection at a dealer but still need to do a coding. Does anyone know how to code it as there is no security code for Sound system in vag com? Sometimes I get one high speaker pop of the dash and 2 does not and also sometimes mmi show B&O tone settings and then it is complete silent, when restart and get standart sound set up, all is ok.
Anyhow it is a night and day so far
will post some pics of installation but it looks harder than it was. 1st I got complete wire installation of the car where B&O was used, then easier to use those wires only for the speakers.
Thank you
It is done
Thank you
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
bilbo6209
10
09-04-2015 04:07 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
