HR: Audi a8 4.2 TDI 2010y problem whit chanel 01 and 11
Help !!!
VIN: WAUZZZ4H License Plate:
Mileage: 462966km-287673mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 1B 22 30 34
36 3B 3C 42 46 47 52 53 56 5F 62 6C 6D 6F 72 81 84 85 8B 8E
8F 90
VIN: WAUZZZ4H Mileage: 462966km-287673miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
22-AWD -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
84-Night Vision -- Status: Malfunction 0010
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CDSB) Labels:* Redir Fail!
Part No SW: 4H0 907 409 HW: 4H0 907 409
Component: 4.2TDI EDC17 H04 0010
Revision: 34H04---
Coding: 0106002C290F0268
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM42TDI1114H0907409 001016
ROD: EV_ECM42TDI1114H0907409.rod
VCID: 69D908A38879EBCEA4-803C
2 Faults Found:
7156 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 00 [039] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 18
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:43
Engine speed: 690.50 /min
Normed load value: 18.8 %
Vehicle speed: 0 km/h
Coolant temperature: 87 °C
Intake air temperature: 43 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.840 V
Unlearning counter according OBD: 40
Vehicle speed: 0.00 km/h
Battery voltage: 13840 mV
Intake manifold runner control (IMRC): offset open: 3.81 %
Intake manifold runner control (IMRC): offset closed: 8.41 %
Intake manif runner actuator: uncond volt actual value: 251.0 mV
Actuator for intake manifold runner control: status-Bits 0-7: 00000000
Actuator for intake manifold runner control: status-Bits 0-7: 01111111
Actuator for intake manifold runner control: status-Bits 0-7: 00001010
5506 - Intake Manifold Flap Position Sensor (Bank 1)
P2016 00 [039] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:43
Engine speed: 691.50 /min
Voltage terminal 30: 13.860 V
Battery voltage: 13860 mV
Intake manif runner actuator: uncond volt actual value: 249.0 mV
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 Q HW: 0BL 927 156 E
Component: 0BL 42 TDIRdW H08 0004
Revision: --H08---
Coding: 001111
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_TCMALX51011 001012
ROD: EV_TCMALX51011_001.rod
VCID: 3E738BFFA177BC7621-806A
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 A HW: 4H0 907 379 A
Component: ESP PREMIUM H08 0151
Revision: -------- Serial number: --------------
Coding: E4FAA200275F4500E300
ASAM Dataset: EV_ESPPremi 004012
ROD: EV_ESPPremi_004_AU64.rod
VCID: 306FA5C76B235A06A3-8064
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DB HW: 4H0 907 064 L
Component: BCM2 2.0 H13 0510
Revision: 00002001
Coding: 01071001000000000000
Shop #: WSC 40525 146 85146
VCID: 6CD771B78F8BFEE6DF-8038
Subsystem 1 - Part No SW: 4H0 905 852 A HW: 4H0 905 852 A
Component: J764 ELV MLB H37 0042
Serial number: 0209000089239007
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 C HW: 4H0 959 760 C
Component: MEM-BFS H07 0114
Revision: AA000000 Serial number: 00001001384025
Coding: 0018320000043201000001010101102130313131282020
VCID: 3365AACB9235611EDE-8066
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 D HW: 4H0 820 043 D
Component: Klima 3 Zonen H14 0045
Coding: 3801002804
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 2149508330C9E38E3C-8074
1 Fault Found:
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [009] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0092
Revision: 15011002 Serial number: 00000000689589
Coding: 0200201151349FF1FB810007A0001900009CC20A0A00010180 0008542100
Shop #: WSC 12345 123 61029
VCID: 3169A0C36829530EAC-8064
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 100504 H32 0040
Serial number: 100525084126
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10930747
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Serial number: 14 05 2010 00000055
Subsystem 4 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H08 0275
Serial number: WA091645000000045764
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 4A084035000000000001
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 010000
VCID: 23455A8B22D5F19E2E-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 C HW: 4H0 919 475 C
Component: PARKHILFE ACC H05 0011
Revision: 11001001 Serial number: 44831015401279
Coding: 300902
ASAM Dataset: EV_AU64XParkiAssis2 005003
ROD: EV_AU64XParkiAssis2.rod
VCID: 326BAFCF652F6816D5-8066
Address 11: Engine II (J624) Labels:* None
Revision: 34H04---
ASAM Dataset: EV_ECM42TDI2114H0907409 001016
ROD: EV_ECM42TDI2114H0907409.rod
2 Faults Found:
10057 - Exhaust Pressure Sensor 2
P047A 00 [039] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Engine speed: 688.50 /min
Normed load value: 18.4 %
Intake air temperature: 42 °C
Voltage terminal 30: 13.760 V
Battery voltage: 13760 mV
Exh gas press sensor 1 bank 2: uncond voltage value: 9.4 mV
Exhaust temp sensor 3: bank 2: uncond voltage: 751.4 mV
Exhaust temp sensor 1: bank 2: uncond voltage: 783.8 mV
Intake air temperature: unconditioned voltage: 4999.8 mV
Temp sensor for engine coolant: unconditioned voltage: 977.2 mV
Coolant temp at radiator output: unconditioned voltage: 825.8 mV
5507 - Intake Manifold Flap Position Sensor (Bank 2)
P2021 00 [039] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Engine speed: 689.50 /min
Normed load value: 18.0 %
Voltage terminal 30: 13.780 V
Battery voltage: 13780 mV
Intake manifold runner control (IMRC) 2: offset open: -7.36 %
Intake manifold runner control (IMRC) 2: offset closed: 4.06 %
Act f int manif rnr ctrl bank 2: uncnd vlt act val Uncnd vlt: 248.0 mV
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X_001.rod
VCID: 295948A348F92BCE64-807C
1 Fault Found:
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Control Module temperature: 32 °C
Voltage terminal 15: 13.905 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H24 0028
Revision: -------- Serial number: 003G10013E50
Coding: 30314246304230303031554A304C34483053
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 356194D394417F2EF0-8060
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405H6O2OU39C$
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405D6O2OU30CR
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB404V6DUG67GSH
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB404V6DUG680P0
Crash sensor for front airbag: driver side:
Serial number: 3554VRB405D6NG4EN0I/
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40596NG4ELHE5
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JCO0002Y
Coding: 0000BC
Subsystem 1 - Part No SW: 4H0 951 528 HW: 4H0 951 528
Component: E221 - MFL H04 0009
Serial number: 26 11 2009 34002863
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 830 F HW: 4H0 920 830 F
Component: TDieRDWACCNV- H30 0185
Revision: 20030116 Serial number: 658090610593018
Coding: 03070800F7000008000000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU64.rod
VCID: 285F4DA753F312C67B-807C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 D HW: 4H0 919 204 D
Component: Analoguhr D4 H04 0210
Serial number: 1100511000504
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000044817
Coding: 00C1037D00
Shop #: WSC 40525 146 97603
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467A9D79F3B6626C7-8060
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0130
Serial number: 00000000005640103607
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 A HW: 4H0 907 144 A
Component: DYNAMIKLENK. H06 0080
Revision: 51001005 Serial number: --------------
Coding: 8B0000
VCID: 2643439F51E704B649-8072
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H11 0013
Serial number: 000806100001037
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 275D4E9B5EED1DBE72-8072
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0020
Revision: S0H06000 Serial number: 00000000003587
Coding: 01010101000000000000000202
VCID: 64C71997675BB6A697-8030
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 B HW: 4H0 907 553
Component: LUFE-DAEMPFER H16 0095
Coding: 008006
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_AirSuspe 003017
ROD: EV_AirSuspe_VW51.rod
VCID: 2B55B2AB420539DE96-807E
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H07 0114
Revision: AA000000 Serial number: 00001001384223
Coding: 0018330000053201000001010101102130313131202020
Shop #: WSC 02391 785 00200
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 A HW: 4H0 907 637 A
Component: SARA 6D red H02 0015
Revision: -------- Serial number: EJ1BPA3700447J0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BCB37C1137EE88-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH02 0060
Revision: 00H02000 Serial number: 6PZ 010 287-00
Coding: 0000101
VCID: 6DD17CB37491F7EEC8-8038
Subsystem 1 - Part No: 4H0 907 568
Component: J770 SWA Slave H01 0060
Subsystem 2 - Serial number: 6PZ 010 287-20
Subsystem 3 - Serial number: 5F25.05.1000H010003CH11541˙
Subsystem 4 - Serial number: H11541˙
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0162
Revision: -------- Serial number: 0000105482545
Coding: 011F02205E2062C202000007
VCID: 3B7582EBBA65A95E06-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0131546945
Coding: 011E062000393D81B32007B28C000008000000000000000000 0000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H11 0070
Serial number: A2010000000000100440
Coding: 010000
1 Fault Found:
03838 - Motor for Rear Blind: Thermal Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:39
Address 47: Sound System (J525) Labels: None
Part No SW: 4H0 035 223 HW: 4H0 035 223
Component: BOSE G3 D4 H07 0050
Revision: CI007500 Serial number: 00000000002383
VCID: 5BB5226B5A25895E26-800E
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0158
Revision: -------- Serial number: 0000104613068
VCID: 3A7B87EFB55F90561D-806E
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 C HW: 4H0 907 801 A
Component: EPB-4 H03 0009
Revision: -------- Serial number: 00000000004079
ASAM Dataset: EV_ParkiBrake 001015
ROD: EV_ParkiBrake_VW51.rod
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4E0 035 053 L HW: 4E0 035 053
Component: Radio U Basic H45 0085
Revision: AB001007 Serial number: 010FV0A7506992
Coding: 010003010000000001
VCID: 254144932CE10FAE40-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 654 B HW: 4H0 035 670
Component: H-BNT-EU H48 1034
Revision: -------- Serial number: 410CJ0BB001049
Coding: 010100000001F9EF7D140F1E00000003000001000000000000
Subsystem 1 - Part No: 8R0 060 884 HQ
Component: EUR 2021 3201
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Serial number: AUZ8ZDA26000RSW
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000009024
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
4 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:44
Freeze Frame:
Text: DU902A,Front,M,0,0,6
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:42
Freeze Frame:
Voltage: 14.10 V
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:42
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
03787 - Rotation Mechanism for Display Module Front
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:41
Freeze Frame:
Voltage: 14.00 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000105602299
Coding: 010F0220402062C202000007
VCID: 397998E3B0599B4E14-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H03--- Serial number: 525PA8-J05D0CV
Coding: 1021002
Shop #: WSC 42396 000 1048576
VCID: 65C10493AC61CFAE80-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 F HW: 4H0 959 107 F
Component: HDSG-Modul H11 0632
Revision: 09145325 Serial number: 138000054
Coding: 0200044000
ASAM Dataset: EV_DeckLidContrUnit 001023
ROD: EV_DeckLidContrUnit.rod
VCID: 3169A0C36029530EAC-8064
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000006484
Coding: 000000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C51A8B6A55B19E6E-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000105602292
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 HW: 4H1 927 731
Component: GSM-LL H07 0083
Revision: 0L0D4011 Serial number: SN100412 0248
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono_AU64.rod
VCID: 6ADB77AF8D7FE0D6AD-803E
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 E HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0026
Serial number: 0K84AE40005530
Coding: 1101
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H07 0006
Serial number: 00000000001011616651
2 Faults Found:
9984 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
4107 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
Voltage terminal 15: 13.9 V
Image processor: temperature: 38 °C
Adjustment malfunction: Not adjusted
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H26 0081
Revision: -------- Serial number: 262130025421000
Coding: F9060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C57B1B7470B3EE69F-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU64X_001.rod
Address 8E: Image Processing (J851) Labels:* Redir Fail!
Part No SW: 4H0 907 107 HW: 4H0 907 107
Component: BV-SG H25 0008
Serial number: 000040052805107
Coding: 01A08201
ASAM Dataset: EV_BVS 001007
ROD: EV_BVS.rod
VCID: 64C719976F5BB6A697-8030
1 Fault Found:
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H04 0070
Coding: 0066F609031F037E070308014240C0010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 6FED66BBB69D05FEFA-803A
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H04 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 70EF65C7ABA31A06E3-8024
End-------------------------(Elapsed Time: 07:44)--------------------------
8F 90
Revision: 34H04---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:43
Revision: --H08---
Coding: 001111
Revision: 00002001
Coding: 3801002804
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
Coding: 0045F7
Coding: 025523
Coding: 020300
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:00
Revision: AA001001
Coding: 010000
Coding: 300902
Revision: 34H04---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Coding: 3604010201
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
Coding: 0000BC
Analog_clock:
Coding: 00C1037D00
Coding: 8B0000
Coding: 008006
Coding: 0000101
Coding: 010000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:39
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:44
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:42
Freeze Frame:
Voltage: 14.10 V
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:42
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
011 - Open Circuit
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Time Indication: 0
Date: 2024.06.27
Time: 10:22:41
Freeze Frame:
Voltage: 14.00 V
Coding: 1021002
Coding: 0200044000
Coding: 000000
ROD: EV_Ambie.rod
Coding: 1101
2 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:39
Coding: F9060000
Coding: 3604010201
Coding: 01A08201
ROD: EV_BVS.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 161
Mileage: 462966 km
Date: 2024.06.27
Time: 10:22:40
quattro25
Canadian Discussion
05-15-2007 06:30 PM
I think i found my next car ( i still am a audi fan at heart) its a '90 nissan maxima se, pearl whit
BmwSlayer is rising
08-26-2005 08:06 PM
Nogaro
Motorsport Discussion
07-02-2001 11:39 PM
