Night vision assistant problems
I have the night vision assistant on a 2012 A8L and I have never had it sound a tone despite the fact that I have this feature turned all the way in the MMI. Sometimes it will feature an animal with a yellow box and sometimes it will not.
The dealer agreed it was a problem and replaced the unit, but it is still the same. Any ideas?
This system is designed only for human detection. Audi states this quite clearly. It is not meant to warn of animals, although sometimes it will highlight them in yellow. It will tone and turn red only if an actual human is seen by the system.
And then it will only turn red and sound the alarm if its computer algorithm computes that the human is moving into the path of the vehicle and that a collision is likely.
Wow! That is totally the opposite of what the dealer told me. My quick look at the manual missed this. I wonder why they have a pedestrian mode if it does not work with animals? By the way, so far it has not worked with people either! What is the mechanism by which it works? I thought is was thermal or infra-red which should work for all warm objects.
What constitutes an "impending collision"? Anyone care to run a test? (I'd do it but down here in Florida we are presently out of the Tempetature range for it to sound alarm.)
Thanks! I see that you have night vision as well. Have you found it to be useful for anything? You obviously can not drive down the road staring at the little screen. I am in rural Wisconson with lots of deer and fox and such and an animal warning would be very useful.
Certainly, it would be a significant improvement if Audi added large animal recognition to the warning system.
I own a 2014 Audi A7 and love it. Recently the night assist is not picking up people and alarm is not working. I looked in the MMI and all items are listed to come on. The top right still shows a line through the two icons. I seen a stream that indicated this will not work on warmer temperatures above 77 degrees F. However I tried in cooler temps still not working. I have cleaned the lens housing and still no function. This feature is great at disco when it’s hard to see people during that time.
Does anyone have a fix or had similar issues? Possible Vagcom fix?
Thank you....
Thank you....
Thank you....
Thank you....
