When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
1. How can you remove these headrests? I struggle to reach back in there to get the window cleaned and removing them would be a huge help. Also planning on getting the windows tinted and I'm sure they will ask as well
2. Anyone replaced them with a lower profile head rest? 9/10 times I have kids in my back seat at 5'0 and shorter. Then even the majority of my adult friends/family are 5'7 at most. Anyone swap with another headrest that doesn't protrude up in the rear window as much? I did this on my MK6 Sportwagen, however since these are electric adjustment, I'm not sure if possible.
Are you saying you have reclining rear seats? The headrests aren’t power adjusted in the rear so they’re easy to take off *IF* you have reclining rear seats. You have to pop off the plastic escutcheon around where the headrest enters the seat back and push a lever and you can pull them out. I’ll go take a pic in a sec to show you.
I’m 99% certain the non comfort ones are a direct swap... however, caveat: I know that the front seat comfort head rests at least are ‘intelligent’ and I believe throws an airbag code if you turn the ignition on with the headrest removed. Not sure if that’s the case with the rear.
I looked into the non comfort rear headrests when I was thinking about having custom rear headrest pillows made before I found OEM ones.
If you don’t have reclining rear seats then you have to remove the seat back to have clearance to pull the headrest out
I do have reclining rear seats. I'll have to stick my head in there again and look.
It slipped my mind t9 go take pictures yesterday when the weather was beautiful, so I took some today while running errands in a monsoon
Since you have reclining seats it’s cake:
-lower rear sunshade
-fully recline rear seats
-squeeze escutcheon inward at the base of the right prong (as you look at the seats- US driver’s side, UK passenger side. Same side for both seats) and evenly pull headrest in the direction of the prongs. The headrest will only move a little bit, a few cm, just enough clearance for the next step [see fig. 1]
-remove escutcheon at the base of the left prong (again, same side for both seats). It is simply a cap that clips into place. I suggest a wide flathead screw driver placed under the edge of the escutcheon and fingers below screw driver shank. Use an upward motion keeping the screwdriver level, it’s held with some pressure given that there’s not much leverage from the position it’s in. Just use slow, firm motion so the screwdriver doesn’t slip and if it does it doesn’t go too far [see fig. 2]
-with escutcheon removed, you will see an exposed mechanism much like the right side. Pinch mechanism at the base of both prongs and lift headrest up and out in the direction of the prongs [see fig. 3]
There exists a non-comfort version of the rear headrest that fits over the front of the seat so it’s much lower profile. Perhaps you would be interested in that as madlife is
Yes I totally would be, Do they still adjust upward if people want to use them? I assume you can source me some of those as well?
If you are going to get it tinted I can tell you the tinter will be thanking you if you remove them. I removed all the back seats when I got my last A8 tinted and will do the same for this one when I get around to tinting this one.
