S8 4.0T water pump cost
My 2013 S8 gave a crazy overheating warning the other day, no heat, coolant reservoir basically empty. Limped to independent shop, thy said its the water pump and thermostat assembly needs to be replaced. Quoted $2,216.72. Does this sound close to right on the cost? Just want to make sure not getting totally hosed
Thanks
Thanks
Moderator
Back in 2019 I paid an independent shop $1,214.74 for a leaking thermostat housing replacement. If a pump in involved that could explain the delta in your quote and what I paid. For context I was just dealing with a leak and not an overheating/coolant dump situation.
Wow, that's pricey. How many miles are on your car?
Super-Duper User
Make sure the loss of coolant is related to failure of the pump and thermostat... You could have a slow leak elsewhere, which would cause that predicament.
09S5 (01-13-2022)
HARLEYKIDD55
06-23-2018 01:12 PM
MarcDC
Mid Atlantic Discussion
9
04-01-2005 11:21 AM
