Steering not straight after removing battery
I have a number of faults on my A8 since removing the battery, the oddest of which is the steering wheel is at about 60 degrees when the car is going in a straight line. I have tried the resetting the steering angle following some instructions I have found online for other vehicles but it doesn't help. Note: nothing mechanical has changed on the car to through the steering wheel alignment out.
Here is the VCDS output.....can anyone offer any advise please:
Chassis Type: 4H (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 1B 22 28 30
34 36 3B 3C 42 46 47 52 53 55 56 5F 62 6C 6D 6F 72 81 84 85
8B 8E 8F 90
VIN: WAUZZZ4H5AN003706
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Malfunction 0010
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
84-Night Vision -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CDSB) Labels: None
Part No SW: 4H0 907 409 M HW: 4H0 907 409
Component: 4.2TDI EDC17 H04 0001
Revision: 34H04---
Coding: 0106002C290F0268
Shop #: WSC 10767 000 1048576
ASAM Dataset: EV_ECM42TDI1114H0907409M 001001
ROD: EV_ECM42TDI_AU64.rod
VCID: 3663C05A89E770AE7EF-8063
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels: None
Part No SW: 4H1 927 158 Q HW: 0BL 927 156 E
Component: 0BL 42 TDIRdW H08 0006
Revision: --H08---
Coding: 001111
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_AU64.rod
VCID: 3E73D87AA1D7B8EEA6F-806B
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 A HW: 4H0 907 379 A
Component: ESP PREMIUM H08 0151
Revision: -------- Serial number: --------------
Coding: E4FAA200275F4500E300
ASAM Dataset: EV_ESPPremi 004012
ROD: EV_ESPPremi_AU64.rod
VCID: 306FF6426B835E9E243-8065
2 Faults Found:
0188 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:14
0679 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:14
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BB HW: 4H0 907 064 L
Component: BCM2 2.0 H13 0333
Revision: 00002001
Coding: 05170001000000000000
Shop #: WSC 00441 210 91426
VCID: 6ADB242A85DFE44E2A7-803F
Subsystem 1 - Part No SW: 4H0 905 852 A HW: 4H0 905 852 A
Component: J764 ELV MLB H37 0042
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 F HW: 4H0 959 760 F
Component: MEM-BFS H07 0115
Revision: AA000000 Serial number: 00001010117478
Coding: 0038320000043201000001010101102130313131282020
VCID: 3663C05A81E770AE7EF-8063
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 4H0 820 043 D HW: 4H0 820 043 D
Component: Klima 4 Zonen H12 0040
Coding: 38A100B80C
ASAM Dataset: EV_AirCondiFront 001048
ROD: EV_AirCondiFront_AU64.rod
VCID: 214903063069E716BBD-8074
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0092
Revision: 15011001 Serial number: 00000000585015
Coding: 0200201050B49FF1FB810007A0001908009DC30A0B00010180 0008402100
VCID: 3169F346688957962BD-8064
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 100218 H32 0040
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 C HW: 4H0 941 531 C
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H08 0275
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 A HW: 4H0 035 108
Component: DVDCAlpine H42 0120
Revision: AA001001
Coding: 010000
VCID: 1E3338FA0917D8EE86F-804B
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901128500290
Coding: 300902
Shop #: WSC 05078 001 104857
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000.rod
VCID: 377DCD5E8EED89A6659-8062
Address 11: Engine II (J624) Labels: None
Revision: 34H04---
ASAM Dataset: EV_ECM42TDI2114H0907409M 001001
ROD: EV_ECM42TDI211_AU64.rod
1 Fault Found:
8169 - Terminal 30
U140A 00 [039] - Open Circuit
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117783 km
Date: 2000.00.00
Time: 00:00:00
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 29591B2648592F56E3D-807C
2 Faults Found:
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
138752 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
Address 15: Airbags (J234) Labels: None
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H22 0026
Revision: -------- Serial number: 003G10011T9H
Coding: 30314246304230303037554A305234483053
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3561C75694E17BB6775-8060
Crash sensor for side airbag; driver side:
Serial number: 3575HRB405T6O2OU49FC
Crash sensor for side airbag; passenger side:
Serial number: 3585HRB40616O2OU81KU
Crash sensor for side airbag; rear driver side:
Serial number: 3515JRB40556094IAOM6
Crash sensor for side airbag; rear passenger side:
Serial number: 3525JRB40556094I8OL4
Crash sensor for front airbag; driver side:
Serial number: 3554VRB405H6NG4E4H7V
Crash sensor for front airbag; passenger side:
Serial number: 3564VRB405H6NG4ECP64
Address 16: Steering wheel (J527) Labels: None
Part No SW: 4H0 953 568 B HW: 4H0 953 568 B
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JD800026
Coding: 00043C
VCID: 326BFC4A6D8F6C8E527-8067
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H06 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 850 A HW: 4H0 920 850 A
Component: TDieGBACC-NV- H30 0185
Revision: 20030116 Serial number: 658300410593023
Coding: 33060800BF002600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K.rod
VCID: 2541171624410B36C75-8070
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 F HW: 4H0 919 204 F
Component: Analoguhr D4 H04 0210
Serial number: 1100417000528
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
Component: J533--Gateway H07 0213
Revision: -------- Serial number: 00000000013606
Coding: 00C1037D00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 3467FA529F9B62BE40B-8061
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0130
Serial number: 00000000005640101450
1 Fault Found:
0021 - Control Module Incorrectly Coded
U1014 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 43
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 HW: 4H0 907 144
Component: DYNAMIKLENK. H06 0070
Revision: 50001005 Serial number: --------------
Coding: 8B0000
VCID: E5C1D716ECC14B36875-80B0
1 Fault Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0077
Hex Value: 0x761A
Hex Value: 0x0C00
Hex Value: 0x0000
Address 22: AWD (J492) Labels: None
Part No SW: 4H0 907 163 HW: 4H0 907 163
Component: 4 Wheel Drive H11 0005
Serial number: 000104100001119
ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: E6C3D01A19C7402E8EF-80B3
3 Faults Found:
0121 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
0122 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H11 0040
Coding: 0800000000
ASAM Dataset: EV_AirCondiHeck 001038
ROD: EV_AirCondiHeck_AU64.rod
VCID: 3169F346608957962BD-8064
Address 30: Special Function II (J843) Labels: None
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0020
Revision: S0H06000 Serial number: 00000000003141
Coding: 01010101000000000000000202
VCID: E4C7CA12E7FB323E90B-80B1
Address 34: Level Control (J197) Labels: Redir Fail!
Part No SW: 4H0 907 553 B HW: 4H0 907 553
Component: LUFE-DAEMPFER H16 0095
Coding: 008006
ASAM Dataset: EV_AirSuspe 003017
ROD: EV_AirSuspe_AU57.rod
VCID: 2B55E12E42A53D46111-807E
2 Faults Found:
0085 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H07 0115
Revision: AA000000 Serial number: 00001010117482
Coding: 00383B0000053201000001010101102130313131202020
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 A HW: 4H0 907 637 A
Component: SARA 6D red H02 0011
Revision: -------- Serial number: EJ13700032JP000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 2D51EF367CB133760F5-8078
Address 3C: Lane Change Labels: None
Part No SW: 4H0 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH02 0060
Revision: 00H02000 Serial number: 6PZ 010 287-00
Coding: 0001101
VCID: EDD1AF36F4317376CF5-80B8
Subsystem 1 - Part No: 4H0 907 568
Component: J770 SWA Slave H01 0100
Subsystem 2 - Serial number: 6PZ 010 287-20
Subsystem 3 - Serial number: 5F14.11.1100H010003CH11702ÿ
Subsystem 4 - Serial number: H11702ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0158
Revision: -------- Serial number: 0000103299896
Coding: 011F12205E21628202000003
VCID: 3B75D16EBAC5ADC6811-806E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0129314573
Coding: 011B0E2200393C85B32007F28E000000000000000000000000 0000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.028 H06 0006
Coding: 001F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H11 0070
Coding: 010000
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS009 H05 0004
Address 47: Sound System (J525) Labels: None
Part No SW: 4H0 035 223 HW: 4H0 035 223
Component: BOSE G3 D4 H07 0050
Revision: CI007500 Serial number: 00000000000926
VCID: DBB5F1EEDA850DC6211-808E
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0158
Revision: -------- Serial number: 0000103391964
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 C HW: 4H0 907 801 A
Component: EPB-4 H03 0009
Revision: -------- Serial number: 00000000001968
ASAM Dataset: EV_ParkiBrake 001015
ROD: EV_ParkiBrake_AU48.rod
VCID: 285F1E225353165EFC3-807D
Address 55: Xenon Range (J431) Labels: 4H4-907-357.clb
Part No SW: 4H4 907 357 HW: 4H4 907 357
Component: ....AFS13.... H01 0070
Serial number: 100416-0004-009
Coding: 11116F33F918FA00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste.rod
VCID: EFEDB53E363D8166FD9-80BA
Left Headlamp Power Output Stage:
H02 0003
Right Headlamp Power Output Stage:
H02 0003
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4E0 035 061 H HW: 4E0 035 061
Component: Radio U DAB H46 0048
Revision: AB001007 Serial number: 014CN0A7504751
Coding: 010103010000000001
VCID: 204F06023363EE1EB43-8075
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 666 D HW: 4H0 035 666
Component: H-BN-EU H48 0078
Revision: -------- Serial number: 408DZ0A7509517
Coding: 010101000001F9EF75140B1E00000003E0010100
VCID: 2A5BE42A455F244EEA7-807F
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1106
Subsystem 2 - Part No SW: 4H0 919 604 B HW: 4H0 919 604 B
Component: DU8 D4 SV NB H44 0021
Subsystem 3 - Part No SW: 4H2 919 600 C HW: 4H2 919 600
Component: E380 BDT D4 H09 0062
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0158
Revision: -------- Serial number: 0000103416137
Coding: 010F12204021628202000003
VCID: 3A7BD46AB5FF94CE9A7-806F
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H03--- Serial number: 525PA8-J96D01F
Coding: 1020003
VCID: E5C1D7162CC14B36875-80B0
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 F HW: 4H0 959 107 F
Component: HDSG-Modul H11 0632
Revision: 09145325 Serial number: 104000309
Coding: 0200044000
ASAM Dataset: EV_DeckLidContrUnit 001023
ROD: EV_DeckLidContrUnit.rod
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000004802
Coding: 020000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: E3C5C90EEAF53506691-80B6
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H09 0158
Revision: -------- Serial number: 0000103416140
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H2 927 731 HW: 4H2 927 731
Component: GSM-RL H07 0082
Revision: 0R0D4011 Serial number: SN100317 0078
ASAM Dataset: EV_GSM2x3Mono 001015
ROD: EV_GSM2x3Mono_AU64.rod
VCID: EBD5A12E02257D46D11-80BE
Address 84: Night Vision (J853) Labels: 4H0-907-547.clb
Part No SW: 4H0 907 547 D HW: 4H0 907 547
Component: NV-ECU-Gen1 H09 0022
Serial number: 0K84AE40003725
Coding: 1101
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H07 0006
Serial number: 00000000001006310725
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4H0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H20 0016
Revision: -------- Serial number: 262130025421000
Coding: EC060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 275D1D1E5E4D1926F59-8072
Address 8B: Adaptive Cruise 2 (J428) Labels: None
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3604010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU57X.rod
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
Address 8E: Image Processing (J851) Labels: None
Part No SW: 4H0 907 107 HW: 4H0 907 107
Component: BV-SG H25 0008
Serial number: 000040051503107
Coding: 01A28201
ASAM Dataset: EV_BVS 001007
ROD: EV_BVS.rod
VCID: E4C7CA12EFFB323E90B-80B1
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308004240C0010000
Shop #: WSC 05078 001 1048576
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 326BFC4A658F6C8E527-8067
End ---------------------------------------------------------------------
8B 8E 8F 90
Revision: 34H04---
Revision: --H08---
Coding: 001111
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:14
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:14
Revision: 00002001
Coding: 38A100B80C
Coding: 0045F7
Coding: 025523
Coding: 020300
Revision: AA001001
Coding: 010000
Coding: 300902
Revision: 34H04---
1 Fault Found:
8169 - Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 117783 km
Date: 2000.00.00
Time: 00:00:00
Coding: 3604010201
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
Coding: 00043C
ROD: EV_RBD4K.rod
Analog_clock:
Coding: 00C1037D00
1 Fault Found:
U1014 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 43
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
Coding: 8B0000
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Count: 56
Count: 1
Hex Value: 0x0077
Hex Value: 0x761A
Hex Value: 0x0C00
Hex Value: 0x0000
3 Faults Found:
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
U1113 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
Coding: 0800000000
Coding: 008006
2 Faults Found:
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
ROD: EV_SARA.rod
Coding: 0001101
Coding: 001F00
Coding: 010000
H02 0003
H02 0003
Coding: 1020003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Time Indication: 0
Coding: 0200044000
Coding: 020000
ROD: EV_Ambie.rod
Coding: 1101
Coding: EC060000
Coding: 3604010201
2 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:07
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 117783 km
Date: 2015.05.14
Time: 19:38:08
Coding: 01A28201
ROD: EV_BVS.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
Infinity_UK
08-22-2014 05:54 PM
