VCDS Mod for Heated Steering Wheel Temp D4 A8 S8
Mod of the week if you will. I recall a few recent posts about folks not thinking the steering wheel was heating up enough. So, try just dialing the temp up via VCDS. Tested and confirmed on my 2015 D4 S8.
Change the temperature of the heated steering wheel:
The factory preset temperature is set to 28 degrees C, if you want to increase (or decrease) it, go to module 16 (steering wheel), Adaptation and select channel 10. The preset value is 28 which relates to 28 degrees. Change this to a temperature of your choice in the New value box. Hit Test button to confirm, then Save to store it. You can recheck if you want by reading the same channel again, which should now show the updated Stored value.
See below for the example I implemented from 28 to 32C. I may dial it another degree or two on next pass.
A while back, I scanned all my modules and emailed Rosstech copies, per there standing request. Since then, probably with much other input, they seem to have gotten more menu options than there used to be. I know I was digging around every module I could access, and these things you're finding weren't there when I still had my A8. Thank you for sharing your discoveries, I have also added this to the list.
Thanks! I'm one of those that have posted that the heating is minimal at best, and my dealer even installed a new steering wheel a few weeks ago, which did...absolutely nothing! same heating temp, low at best.
Actually, stay tuned. Need to try one more tweak, but so far I have it implemented as long as you hold down remote button continuously. Is that how Europe works? Audi doesn't like things closing by themselves without operator monitoring--for legal reasons...
Great. Yes that's how it works in europe.
