VCDS Starer Code P3054! Help!!
2011 A8 4.2
Got this code today when I tried starting car, at first it cranked but no luck. After a few try’s it just lights up dash screen comes up and then goes back down after a few seconds but air is working lights are working etc... no clicking noises either weirdest thing.
Also front and Rear sunroof will not function, all lights working upper center controls.
Soft close doors as well and both mirrors not closing. PLEASE before I start digging for the starter, any advice??
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
48-Seat, Rear, DS -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
5B-Seat,Rear,PS -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
85-On Board Cam. -- Status: Cannot be reached 0100
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8E-Image Processing -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (------CDRA) Labels:| 079-907-560-CFS.clb
Part No SW: 4H0 907 560 C HW: 4H0 907 560
Component: 4.2l V8/4V H07 0005
Revision: N5H07---
Coding: 0106000A290F0268
Shop #: WSC 08468 002 1048576
ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
ROD: EV_ECM42FSI011_AU64.rod
VCID: 2A0D07888C70ADBB2DF-807E
1 Fault Found:
5456 - Starter Will Not Turn
P3054 00 [229] - Jammed or Electrical Malfunction
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 197242 km
Date: 2020.05.15
Time: 15:21:52
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 15 °C
Intake air temperature: 18 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 12.086 V
Unlearning counter according OBD: 40
AFS dm: 0.0 kg/h
Median injection timing: 0.000 ms
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 AD HW: 0BK 927 156 K
Component: 0BK 42 FSIUSA H08 1007
Revision: --H08---
Coding: 000002
Shop #: WSC 02133 444 55848
ASAM Dataset: EV_TCMALX51011 002018
ROD: EV_TCMALX51011_002_AU64.rod
VCID: 72BDDFE86420A57B55F-8026
No fault code found.
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 C HW: 4H0 907 379 C
Component: ESP PREMIUM H10 0273
Revision: -------- Serial number: --------------
Coding: 44E6F20022674F00E200
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 323D1FE8A4A0E57B95F-8066
3 Faults Found:
0738 - Function Restriction due to Faults in Other Modules
U1113 00 [136] - -
[Net_SARA_06_Accel_X_010_not_calibrated]
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 23
F-Type: 3F
Uz: 9B
0739 - Function Restriction due to Faults in Other Modules
U1113 00 [136] - -
[Net_SARA_06_Accel_Y_010_not_calibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 1A
F-Type: 3F
Uz: 9B
0740 - Function Restriction due to Faults in Other Modules
U1113 00 [136] - -
[Net_SARA_06_Omega_Z_010_not_calibrated]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 1B
F-Type: 3F
Uz: 9B
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 AD
Component: BCM2 2.0 H24 0510
Revision: 00002001
Coding: 0D872000000000000000
Shop #: WSC 44401 000 1048576
VCID: 6E85CB987098819BB17-803A
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000039380008
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00001002360752
Coding: C018B60085043201010001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 353724F4554EF243B0D-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 E HW: 4H0 820 043 E
Component: Klima 4 Zonen H14 0063
Coding: 488122BE8C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 221DEFA8F44075FB65F-8076
2 Faults Found:
0292 - Running-in regulation
B10C6 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
0369 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000962991
Coding: 09072091073C9FE18B000804A0003800009CD3088200012180 01085C3B00
VCID: 2C0101908604B38BDF3-8078
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 110209 H32 0040
Serial number: 110223221638
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10064860
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 04 02 2011 00000031
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0CPP06
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000021021100010428
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000021021100010434
Coding: 100000
Subsystem 7 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA101933000000193484
Coding: 020300
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: C048C395000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 D HW: 4H0 035 108
Component: DVDCAlpine H42 0180
Revision: AA001001
Coding: 010000
VCID: 211FE0A4F1C66EE37C5-8074
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901105300974
Coding: 300902
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 372B2EFC4FC20053A21-8062
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 561 A HW: 4H0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContrAU64X 001012
ROD: EV_AdaptCruisContrAU64X_001.rod
VCID: 290FF8848976A6A3245-807C
10 Faults Found:
22016 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
Control Module temperature: 27 °C
Voltage terminal 15: 12.396 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
22272 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_02]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
22528 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_03]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
22784 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_04]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
23040 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_05]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
23296 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_06]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
23552 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_07]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
23808 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_Linie_08]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
91648 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_BV_POSITION]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:14
Voltage terminal 15: 12.342 V
154624 - Door Contact Switch
C1076 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.15
Time: 15:17:51
Control Module temperature: 30 °C
Voltage terminal 15: 12.134 V
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H41 0041
Revision: -------- Serial number: 003JS0012K5Z
Coding: 303143303230303030314A55304C34483053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Seat occupied recognition:
Subsystem 1 - Part No SW: 4H0 959 339 HW: 4H0 959 339
Component: BF-Gewichtss. H02 0040
Serial number: 5850000R1120901DNK
Coding: 000000
Crash sensor for side airbag: driver side:
Serial number: 3575HRB404T0G68U41HM
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404R0G68UAP2-
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB406109GGS79B6
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB406909GGSBPP6
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40516P1I86884
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB404V6P1I8G0E%
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 B HW: 4H0 953 568 B
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KBE0001D
Coding: 0004BC
VCID: 323D1FE8A420E57B95F-8066
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H04 0009
Serial number: 05 01 2011 33038344
1 Fault Found:
02797 - Control Module for Directional Stabilization Assistance (J759)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Time Indication: 0
Date: 2020.05.15
Time: 15:13:36
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 980 C HW: 4H0 920 980
Component: TBenUSAACC--- H30 0309
Revision: 31110016 Serial number: 658230211593044
Coding: 0B4608015700D705020000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU64.rod
VCID: 2B03028C838AB4B3D69-807E
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1110224000001
1 Fault Found:
16776969 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[LDW_02_FR keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4H0 907 468 E HW: 4H0 907 468 C
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000103010
Coding: 00C1034A00
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 33331AEC5BBAEC739E9-8066
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650660460
2 Faults Found:
4888 - Camera control module
U107A 00 [009] - No communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Voltage terminal 30: 12.2 V
Voltage terminal 15: 12.2 V
Control Module temperature: 35 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
6653 - Image processing control module
U1079 00 [009] - No communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H11 0040
Coding: 0000000000
Shop #: WSC 02133 444 12538
ASAM Dataset: EV_AirCondiHeck 001038
ROD: EV_AirCondiHeck.rod
VCID: 313F10E4A1A6DE63EC5-8064
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008002
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2C0101908684B38BDF3-8078
5 Faults Found:
0920 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
0666 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
0665 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
0769 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002360346
Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA3100D7R20
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6C81C1904604738B9F3-8038
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 HW: 4H0 907 566
Component: J769 SWA MasterH02 0100
Revision: 00H02000 Serial number: 6PZ 010 287-00
Coding: 0000002
VCID: 6D87CC94719E7A8388D-8038
Subsystem 1 - Part No: 4H0 907 568
Component: J770 SWA Slave H01 0100
Subsystem 2 - Serial number: 6PZ 010 287-20
Subsystem 3 - Serial number: 5F24.02.1100H010003CH10512ÿ
Subsystem 4 - Serial number: H10512ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0162
Revision: -------- Serial number: 0000113456756
Coding: 011F1F205E0062C202000007
VCID: 3B2332CC736A2433469-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0144335207
Coding: 0106023A00FA759FB0B0C78002010000000000000000000000 0000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000022111
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 000C H05 0004
Serial number: 107700038198
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2011000000000344745
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0060 H05 0004
Serial number: 107700038072
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 007A H05 0004
Serial number: 107700038187
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00F0 H05 0004
Serial number: 107700038070
Coding: 020200
Address 47: Sound System
Cannot be reached
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 HW: 4H0 959 860
Component: MEM-FS-Fond H06 0153
Revision: AA000000 Serial number: 00001002356887
Coding: 001892800000300D0A00392038193A2039203B3B202020
VCID: 71BFD0E461A69E63AC5-8024
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0162
Revision: -------- Serial number: 0000113410432
VCID: 3A2D37C87C501D3B5DF-806E
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000046851
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
1 Fault Found:
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
Voltage terminal 30: 12.4 V
Internal Fault ID: 185
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 56: Radio
Cannot be reached
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0153
Revision: AA000000 Serial number: 00001002356965
Coding: 001896800000300D0A00392038193A2039203B3B382020
Address 5F: Information Electr.
Cannot be reached
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000113403981
Coding: 010F1F20420062C202000007
VCID: 392F28C479561623545-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H04--- Serial number: 525 PA8J11D1OR
Coding: 1020003
Shop #: WSC 02391 785 00200
VCID: 6597B4B4A96E42C3C0D-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 056100121
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3B2332CC73EA2433469-806E
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000025125
Coding: 000000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393AAACABDA3CF32E9-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000113385727
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H07 0083
Revision: 0L0D5012 Serial number: SN110113 0047
ASAM Dataset: EV_GSM2x3Mono 001017
ROD: EV_GSM2x3Mono_AU64.rod
Address 85: On Board Cam.
Cannot be reached
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00000003289002
Coding: 764FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F3B169CB792C893FA1-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00000003297802
Coding: 364FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00000027052402
Coding: 200F00
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: 2E050B98B098C19BF17-807A
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4H0 907 541 A HW: 4H0 907 541
Coding: 3601020201
ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
ROD: EV_AdaptCruisContr2AU64X_001.rod
VCID: 270BFEBC9F6290D3321-8072
6 Faults Found:
27136 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_BVS_STATUS]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:39
Voltage terminal 15: 12.270 V
Velocity_vehicle_reference: -0.00 m/s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.15
Time: 15:17:51
Control Module temperature: 28 °C
Voltage terminal 15: 12.168 V
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_VDC_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
Control Module temperature: 31 °C
Voltage terminal 15: 12.360 V
134656 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_AXV_ADJUSTMENT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
136192 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_YAW_ADJUSTMENT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_ECD_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:08
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00000106090802
Coding: 200F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing
Cannot be reached
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066F609031F007E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 6FBBD69C77128893BA1-803A
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 70B9D5E06A2C976BA3B-8024
End----------(Elapsed Time: 02:58, VBatt start/end: 12.4V/12.5V)-----------
Revision: N5H07---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 197242 km
Date: 2020.05.15
Time: 15:21:52
AFS dm: 0.0 kg/h
Revision: --H08---
Coding: 000002
3 Faults Found:
U1113 00 [136] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 23
F-Type: 3F
Uz: 9B
U1113 00 [136] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 1A
F-Type: 3F
Uz: 9B
U1113 00 [136] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 82
Bit Info 4: 00
F-Path: 1B
F-Type: 3F
Uz: 9B
Revision: 00002001
Coding: 488122BE8C
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Coding: 0045F7
Coding: 025523
Coding: 100000
Coding: 100000
Coding: 020300
Revision: AA001001
Coding: 010000
Coding: 300902
Coding: 3601020201
10 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:11
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.16
Time: 18:40:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.15
Time: 15:17:51
Coding: 000000
Coding: 0004BC
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Time Indication: 0
Date: 2020.05.15
Time: 15:13:36
Analog_clock:
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Coding: 00C1034A00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:38
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 0000000000
Coding: 008002
5 Faults Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
U1112 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
Coding: 0000002
Coding: 020200
Coding: 070000
Coding: 020200
Coding: 020200
Coding: 020200
Cannot be reached
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 56: Radio
Cannot be reached
Cannot be reached
Coding: 1020003
Coding: 0210044100
Coding: 000000
ROD: EV_Ambie.rod
Cannot be reached
Coding: 764FF2
Coding: 364FF2
Coding: 200F00
Coding: 3601020201
6 Faults Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 197242 km
Date: 2020.05.15
Time: 15:13:39
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.15
Time: 15:17:51
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:07
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:06
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 197242 km
Date: 2020.05.16
Time: 18:31:08
Coding: 200F00
Cannot be reached
Honestly I’m not sure what it is, so when I hit the break and start button mmi comes up and then boom stops and I hear it in the back right like it’s trying but just stops.
also the dashboard is showing 0 mph like the car is on and in park.
