Videos in MMI
Hi guys-
I have a few videos that I loaded on an SD card to have in the vehicle.
Unfortunately only 2 of them play - both from YouTube.
The rest just tell me "... is damaged" and they get greyed out in MMI.
All the videos can be played just fine on a Mac or Windows.
I converted them to MP4 on a Mac and removed all the ._ files from the card.
These were all converted from larger format iTunes files to the 720x576 max size that Audi specifies.
None of them have DRM, and the bitrates used are pictured below.
Any ideas?
How do you guys put movies on SD cards?
Thanks-Jake
Any ideas?
Thanks-Jake
![](http://i917.photobucket.com/albums/ad19/jakematic/Convert.png)
Seems to be an issue with resolution of the video.
Transcoded an Audi commercial I love to 480x270 iPod Touch format and it worked fine.
Now re-encoding some movies overnight and will try again in the morning.
Well... that didn't work. ARGGG!
Looking at some of the files, the bitrates and size don't seem to matter that much.
One file was way larger than originally thought and one had a very high bit rate.
The only thing that was consistent between those that wouldn't play was an additional codec: Text
Assuming that is for subtitles.
On the upside, anything that could be played was able to be imported into the Jukebox.
I've got half a mind to re-encode these with ffmpeg at the command line since you can more finely control the options there.
Notice: I do not condone the concept of DRM, nor the removal thereof to pirate works of art.
If you chose to remove DRM you are on your own and I will not tell you how.
DRM was removed for my personal use only, from legally purchased media.
Be honest and don't steal other people's work !!
The tool that I used to remove the DRM did some funky things with the stream mapping at encoding time.
Audio was mapped to S0 as AAC - ffmpeg users will understand what that means.
Based on this thread and others in the Q7 & A7 forums I pieced it together.
The key is to re-encode with something like Handbrake set to Universal, and bitrate set to 1800kbps.
Two pass encoding of course makes the video look better.
I tried iPhone/iPod Touch but the quality was too low for my tastes.
Settings that worked:
![](http://i917.photobucket.com/albums/ad19/jakematic/Handbrake_for_MMI_device_is_Universal.png)
Green Police
Green Police
K9
I assume then that you have video in motion set up? I had VIM on my Q5 nut have not tried it on our new 2012 A8L yet. Sounds like it is more efficient to rip movies to an SD card that use the dvd changer.
Absolutely better to put them on SD card in my opinion and you can still copy them to the jukebox from SD.
Not that I'm aware of.
BSK
11-15-2005 04:29 PM
bmwslayer
12-19-2001 01:22 AM
SmokeyA4turbod@ebay
11-21-2001 04:56 AM
