Europrice Matrix Headlight activation
#41
Hi angry. I did provide Europrice the VIN, which I suppose was given to Sam. Regarding the hi-beam issue, they do activate manually by pushing the stalk away from you..at any speed. This turns OFF the matrix function and allows the hi-beams to function normally. You don’t have to pull the stalk and hold the hi-beam “flash.” In essence, you are able to switch between matrix and normal hi-beam functionality. Hope that clears things up.
Also, any change to laser functioning? Any pics of blue led lit up in headlamp before after coding?
#42
So I think the Matrix function replaces the Auto High beam function essentially, with Matrix On over 25mph and Laser on over 48mph. This is toggled by pushing stalk between Off/Matrix on/Manual on. Correct?
The following 3 users liked this post by derfA8L:
TonyDetroit
01-03-2003 12:46 PM
audiophilitis
09-19-2001 11:45 AM
