1993 100CS Spraying Coolant
My engine started spraying coolant from somewhere just forward of the driver side, up and back toward the driver. Looked like a few pints at least on the ground. Got it to the shop, and they couldn't find any holes or leaks, hoses detached, etc., even with pressure on the system. Is there some discharge mechanism that might have kicked in? The shop is going to check it over more, but I thought someone on here might have a suggestion.
OK - repair place found problem - plastic fitting at bottom of the radiator cracked. Need to replace entire radiator, apparently routine maintenance, the plastic gets weak and cracks over time.
Audi_in_Van
12-04-2007 06:05 AM
