1994 Audi 100 CS Quattro - Power locks, stereo, and side power seat getting no power.
It's a 1994 100 cs quattro, and I'm thinking that maybe an in-line fuse blew somewhere. All the fuses in the fuse panel are fine. I cant find the wiring diagram anywhere to find out if those three things connect at a central point, or if the locks and the stereo do (the power seat might be a separate issue). Thanks for your help.
You're ignition switch is probably bad. They fail about every 5 years and cause random electronics to not be powered. Don't recommend driving until you fix it as your radiator fans might not be coming on.
More info in the FAQ:
http://forums.quattroworld.com/a6100/msgs/3.phtml
|skolnick
05-14-2007 10:58 AM
