1994 Audi 100 S Air bag Light
Old 03-27-2007, 06:54 AM
New Member
mpradeep's Avatar
Default 1994 Audi 100 S Air bag Light
Recently, I had the airbag light come on, and after pulling codes, it showed:
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
I was told that I need to replace the clock spring ($500 for parts, $200 labor ).
I also have a bad ignition switch. Could a bad ignition switch cause some electrical problem for the airbag light to come up? If so, I would want to replace that first... any ideas?
Thanks!
Old 03-27-2007, 11:59 AM
Tech Guru
4Driver4's Avatar
Default You can try resetting the light when you change the ignition switch, but...
it will probably be back. High resistence to ignitor is 99% chance that you have a bad clock spring.
Old 04-03-2007, 02:59 AM
New Member
mpradeep's Avatar
Default Re: You can try resetting the light when you change the ignition switch, but...
Thanks! It indeed was the clock spring - a $1000 replacement
Old 12-30-2007, 11:06 AM
New Member
muddymatt's Avatar
Default Re: 1994 Audi 100 S Air bag Light
Hi, greetings from New Zealand!
I have a 1994 100 Quattro and just yesterday the Airbag light came on while driving. Can you please tell me how you got your fault codes out and what table or list you used to reference what each code means?
Thanks, Matt
gcpgcp
Audi 100 / A6 (C4 Platform)
14
12-08-2006 06:09 PM
essvar
08-14-2006 09:01 AM
T-28-Quattro de VT
05-15-2004 09:36 PM
Brdman*
03-06-2004 04:25 AM
Quick Reply: 1994 Audi 100 S Air bag Light
