1998 A6...Big problem
Can someone please help me!! Ok so I am probably the biggest idiot in the world. Here is the story, I have a 1998 A6 Quattro Wagon. It is in prefect shape. 164,000 miles, and in great shape runs like a CHAMP! I replaced the fuel filter, brake hoses, and a few other minor things. So I needed to change the spark plugs, I put in some real nice iridium ones. Easy change, done it a bunch of times before. Well when I was pulling out the old ones, which had not been changed in a long time, I noticed one of the old plugs had a broken side coating. Well when I pulled it out, a piece broke off and fell into the cylinder. Well the stupid side of me didn't really worry about it, and I went to start. I started it and now it runs like it's been through a war. It won't idle right, sounds terrible when I give it gas.
What did I do?? Did I totally screw my engine up? I am just a novice but I love to work on my car. Could a little piece of plastic ruin anything? Wouldn't it just crumble up and blow out the exhaust? I am pretty sick to my stomach right now so any help and advice would be awesome. Thanks!!
I've tried just my home vacuum, and i taped a hose to the end of it but that didn't seem to work. The thing is that I cranked it for a few seconds, do you think the little piece could have gone somewhere else in the engine?
Watch the following Youtube video to see how to get foreign objects out of a cylinder.
http://www.youtube.com/watch?v=qDL3i6mT8V4
that video was great. yeah so i tried vacuum it out but that didn't work too well. i found a good idea to put some thick grease on the end of a non abrasive wire or small hose and stick it out. I was able to pick out 3 small pieces, but i am pretty confident that there is still a bigger piece in there. i will get my hands on an air compressor and try blowing it out. that was a great idea. thanks for the help i am really worried that a valve or something a ruined. i really wouldn't trust myself with taking the head off, but at the same time I don't wanna fork out a bunch of money. i'll keep trying and let you know. thanks again.
Get a socket and breaker bar and crank the crank shaft pulley until the piston is at top dead center. BTW turn the socket clockwise. By getting the piston to TDC this will close the intake and exhaust valves.
Also remember to check the spark plug; the electrode might have been damaged by the foreign object.
Good Luck
Good Luck
thanks everyone for your help. i ended up getting the pieces out of the cylinder by first greasing up the end of a real long cotton swab and sticking some out. i then started it without that particular plug in, and a whole bunch of carbon build up as well as a few more pieces came shooting out. it started up great, i checked the plug it was fine, and it ran fantastic. although at one red light the idle dropped pretty low. that only happened once, so if it happens again i'll look into it. so i think i am good to go until i jack something else up! thanks again.
sergeyk
Audi Original "S" Cars
03-29-2005 01:33 PM
4g63T
12v V6 Discussion
9
05-05-2004 07:10 AM
