93 cs100 door latch
I have recently discovered a problem with my passenger side door. The interior door latch does not open the passenger side door. The door can only be opened from the outside. Does anyone have good instructions on removing the door panel, or fixing this problem. I appreciate all help.
Tim
'93 CS100 105K
Tim
'93 CS100 105K
sure- not 100% sure on the 100's, but I'll take a stab from what I remember off the 95 I did:
Take the plastic cover off where the door handle is.
Remove the visible screws there.
Remove the screws on the side of the panel- top left and top right, where the panel wraps around the door.
Pull the inner handle out, there is a screw back there that you need to get to. Pull the handle forward, then out. Disconnect the switches, and unlatch the wire with the hook at the end that goes to the moving part of the handle. there is a foam piece you will have to remove.
Lift the whole panel UP, then out.
Reverse to install.. Look at the white insulated metal wire that latches to the door latch. See if you can see anything wrong.
Bisqueth
03-31-2009 02:24 PM
SCarGo02
13
08-19-2003 01:26 PM
