'96 A6q tires and wheels
Can anyone comment on wheel and tire combinations that will be "bigger" without causing problems in the openings.
Street oriented combinations with large wheels and low profile tires ARE NOT what I'm after. I would like to fill in the "gaps" though.
If I had the overall tire diameter, and width from any conbination that "works". I could select a combination that suits my back road driving requirements.
When I went to the tires and wheels form. the topic all seems to be "street style", but I will ask there as well.
How about 225/60-16? Fit or hit?
CalG
CalG
and that would be a 205/60-16. 225/60-16 combi would be too wide(225) for the diameter(60) and would rub on the inside housing on a full steering turn.
205/55-16 - standard width & height for 16"
225/55-16 - wider / same height
205/60-16 - same width / higher(diameter)
225/60-16 - wider / higher(diameter)
It's a challenge to fill in the fender gaps on the 100/A6. Going with 205/60-16 would look like having snow tires on 16"...allroad look?
size--------diam----error----revs per mile
205/55----632----0----------811 (=OEM size)
215/55----643----1.74%---797
215/50----621----1.66%---824
225/55----654----3.48%---783
225/50----631----0.08%---811
clancy
Wheels & Tires Discussion
04-24-2008 08:09 AM
Steven S.
09-09-2002 06:44 AM
kkii9
07-09-2002 05:30 PM
huachele
02-15-2001 08:30 PM
jasonmis
11-11-2000 05:24 AM
