A6 headrests, center console, and guages?
Is it possible to switch out the headrests from a 92CS to those of a 94-97 A6? I'm guessing the posts for sliding the headrest in is at the same distance apart as the ones in the 100's (since the seats look the same except for headrests), but wasn't sure. I like the center console from the A6's too (with the wood trim around the shift selector) and wonder if that fits the 100 as well?
Also, are the guages from an 94-97 A6 (with the aluminum rings) a direct replacement (connectors, etc)? How will the guages/system check/radio display be affected?
Just curious...if these work I may be scouring the junkyards around here. :-)
<center><img src="http://www.intense-motorsports.com/pd721251872.htm?categoryId=0"></center><p>I found this in the tech section. Does anyone know if the gauge rings for an A4 are the same as a 100? Intense accessories sells the A4 rings for 72, so even if they fit you might be able to get them cheaper off an A6 at a u-pull junk yard.<ul><li><a href="https://www.audiworld.com/tech/int43.shtml">https://www.audiworld.com/tech/int43.shtml</a</li></ul>
<ul><li><a href="http://www.intense-motorsports.com/pd721251872.htm?categoryId=0">http://www.intense-motorsports.com/pd721251872.htm?categoryId=0</a</li></ul>
4rings2turbos
New England Discussion
09-20-2006 06:59 AM
OpusK551
09-30-2001 10:39 PM
