Audi A6, 1996 - Strongly knock of the valve.
I don't know if it is can be normal.
When the engine is working on 800-900 rpm I can hear a strongly knocking of the valves. It is unusual for other cars that I've had. Should I do something with this? Is it dangerous? What should I do to reduce this knocking.
Many thanks!
Many thanks!
Oops - that sounds even worse...
Can you pin point location? i.e. long screw drive with blade end on valve cover and handle end to your ear and move it across V/C until it is loudest or is it even coming from the valve cover(s)?
Redneck Truck
08-27-2011 11:10 AM
