Auto trans problem on Urs6.
#14
Here's some more info about ZF applications in Audis
from this page: http://www.audipages.com/Tech_Articles/auto_transmission.html
I still can't find the exact reference I've been searching for...<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/ZFAudiProgram.pdf">http://www.audipages.com/Tech_Articles/auto_transmission/ZFAudiProgram.pdf</a</li></ul>
#15
More
I've been looking for the equivalent document for your transmssion, but can't find it. Maybe this will give you some indication of availability of gaskets for ZF valve body, in general.<ul><li><a href="http://www.zf-group.com/pdf/5HP19FLA.pdf">http://www.zf-group.com/pdf/5HP19FLA.pdf</a</li></ul>
#16
Thx, DaveInSaltLake..
I flushed the oil last time and filled up with the dexron3 grade.can this zf tranny applicable for the dexron grade oil? this's supposed to be the first time since i've got this car.
anyway,i knew that the ex-owner also used the dexron oil before the car'll be on my hand. I'm just wondered if the dexron oil is probably harm to the tranny?anyway, I asked the audi authorized dealer in local.they said there's no valve body's gasket available .From ETKA, my tranny probably is ''CRG''code.(there're 4-5 codes for the tranny on the UrS-car).
Anyway,I'm thinking to flush the tranny oil again with oem ATF.hope it will help,for the gasket for valve body.I need to ensure if what exactly the tranny code or part no. and oeder via the zf 's site. second option,go for the used tranny.
that would cost me around $1500.
#17
Check this reference for your transmission code
http://www.oilshop.ro/catalog/vagvin.php
I don't have any experience using Dexron in any of my Audis. I think some people have used it without problems, but your tranny may need the originally spec'd fluid.
This is a LONGSHOT, but if you take your tranny pan off again you should check to see if it's at all similar to this one...and do the DIY that has helped a lot of VWs.
http://forums.tdiclub.com/showthread.php?p=584164
There are a number of companies that make rebuild kits for the ZF transmissions. Someone is bound to make the gaskets you're looking for. Frankly, I think there's a low probability it's the gasket.
You should find someone with a VAGCOM and perform a Output Diagnostic Test on the transmisison. It tests all the solenoids and electrical parts in the tranny...it might just pick up on something to help you diagnose the problem. Also use the VagCom to check for any DTCs stored in the Trans Control Module (TCM). I use a cheaper cousin of VagCom, VWTOOL, combined with OBDTOOL to do this on my Audis.
If you do get any codes, make sure you write them down and we can help you interpret them every which way to Sunday.<ul><li><a href="http://www.oilshop.ro/catalog/vagvin.php">http://www.oilshop.ro/catalog/vagvin.php</a</li></ul>
#18
I've ever diagnosed with the VAG com..
There's no any faults in the tranny or else.
Now I'd like to remove the pan off and flushing
with the oem oil.and see if anything better.
i'm looking for the valve body gasket because
I'm planning to clean up the valve body if
the flushing doesn't help.So I need to find
gasket in case of anthing goes wrong.I'll keep
in touch with you if any further.
Thanks
pop
Thanks
pop
pilotsr
Audi 100 / A6 (C4 Platform)
06-28-2004 09:44 PM
Tornado //S6
01-23-2003 03:03 PM
