Bilstein Strut Clunking
I installed Bilstein HD struts in my '96 A6Q all around. The left front started clunking shortly afterward. Mechanic said it was a faulty strut. Bilstein sent a replacement but the same thing happened...clunking. It also sounds like it is binding when I turn the steering wheel to the left. Doesn't do it when I turn right. The mechanic has checked all the bolts several times. All okay. I've read some posts here that some struts don't fit snugly in the housing causing movement and noise. Has anyone solved this kind of problem with Bilsteins?
It was standard procedure on the 1988 Audi's to put 90 manual transmission oil into the strut housing but I have not seen this on later models.
I would rather use a shim under the cap nut which holds the shock into the strut to ensure that the shock is firmly pressed down and cannot move.
There must be a cap nut holding the shock in the strut tube.
And no - please don't use oil or grease. Like I said the early Audi's used this method but there must be a good reason why they stopped doing it.
Unbelievable. The replacement strut from Bilstein also went bad. My mechanic pulled it and there's fluid all over the strut housing. None in the strut insert where it's supposed to be. This strut started making noise when first installed. Got gradually worse, over the past year, until I couldn't stand it anymore. Ordered a replacement from eShocks.com...where I bought it. I couldn't get three bad shocks in a row...could I?
My mechanic didn't want to put the bad insert back in so he bought a new Boge Turbo-Gas shock and installed that. When the Bilstein gets here, he'll put that in and use the Boge in his '93 S4. What's it cost for that kind of service you ask? No charge. What great guy! Ted Savas, Val's Foreign Auto Repair, Haverhill, MA.
quattromano
09-19-2003 12:32 AM
