Brdman*, where'd you tap into the power mirror for your stereo power?
I could also use a power window wire right? They have power after I shut the car off until I open the front doors or pull out the key.
If you know of an accessible wire under the dash or something, let me know.
Thanks
Dave
Thanks
Dave
It was actually the side mirror adjustment switch...
i got the swiched power from. On the 100, this switch is located directly to the left of the stereo.
Try getting a switched power from the switches above the radio. You need a multimeter...
Ok, my side mirror adjuster is in the door....
I have a multimeter and have been looking for the last hour. I would like a wire that has power when you turn the key back to off, such as the power windows. I found some wires leading to the power window relays but were only 4.32 volts. Why would this be?
The power sunroof is just like the windows but the switch is in the roof so that probably doesn't help any, but I'll go check again for any other switches.
UCLA Matthew
07-09-2005 05:38 PM
audiman231
06-30-2005 10:29 AM
Phishloco
07-01-2004 04:01 PM
