Are the C4 automatic and C4 standard transmission chassis identical? What I mean...
is are the transmission and engine mounting points the same for a quattro chassis regardless of whether the car has an auto box or a five speed std. trans?
Some manufacturers have different size trans humps, etc. but I have no clue whether Audi does this or not. (My 93 S4 has a five speed and I looking at buying an C4 A6 avant and swapping engines and transmissions, etc. - At least in my dreams).
TIA
TIA
same chassis and transmission hump...
the motor and transmission mounts are different, but they can be taken from the donor car. A6 and S6 shared transmissions all down the line.
<img src="http://pictureposter.audiworld.com/37457/engine.jpg">
<img src="http://pictureposter.audiworld.com/37457/gearbox.jpg">
Re: same chassis and transmission hump...
is the gearing for the differentials the same?
ie, if i have an auto and want to swap in the manual setup, do i have to change the rear diff as well?
Re: Per my Bentley, the manual rear diff has different gear ratio than the rear diff for an automati
automatics get the 4.11:1 final drive (aat code,same as s-car) and the manual gets the 3.89:1 (same as 200q) BTDT
tkursh
06-24-2015 09:18 PM
myfirstimport
11-11-2004 10:07 PM
BrianG
10-04-2003 08:36 PM
