C4 transmission
I need help my 1996 a6 quattro transmission only has manual 1st and rev when I put it in drive it will move forward but as soon as I give it any gas the car stops and makes a rubbing noise from under the car any ideals would be greatly appreciated Thanks
There isn't a transfer case... there's a front diff, a center diff, both built into the transmission casing, if either is shot, you'll have to replace the transmission. There's also a rear diff which is separate and not that expensive used. I don't know how to tell which if any is bad. You may have some luck if you put the car on jackstands and rotate each wheel then rotate the driveshafts and listen for odd noises and make sure the opposite wheel turns as it should.
Look underneath, if any drive shafts or drive flanges off the transmission are moving while in gear but the car is not you have a broken axle joint or possibly rear diff. If not you may have a failed transmission.
j2mc
13
04-04-2017 11:59 PM
porshapower
10-11-2013 07:44 PM
schnitzelboy
03-15-2006 09:03 AM
maaliish
09-10-2004 12:13 PM
