Can I use stock A4/A6 wheels on a 92 100 csq?
Hi all
This is my first audi and I want to swap wheels with newer wheels on the A4/A6. Will those applications work on a 92 100csq? Also, for those running 17" wheels, what is the proper offset without using spacers and the tire size...225/45 or 235/45-17? Also, is anyone using hubcentric rings?
TIA
TIA
you're getting A4/A6 rims. Offset should be 45mm on any of the rims you get. Anyways, I'm pretty sure the A4/A6 rims will fit perfectly with zero modification/spacers/rings.
