cannot communicate with OBD I
Audi 1994 100 S
My mechanic used the "Retriever" scan tool, and he could connect to the obd computer (the cost of the tool is $800). Another mechanic used the vag-com software/tool from ross-tech, and could connect to the obd. i wanted something cheap, so:
1. Bought the obd-II cables off ebay (with 2x2 connector), and tried using the vag-com software from ross-tech, but could not communicate with the computer. I thought maybe the 2x2 connector was bad
2. Bought a handheld scanner (geniscan 200) off ebay (with a new 2x2 connector), still could not connect to the obd. got an error message that implied no communication with the obd computer.
3. checked the obd pins, and they have one wire going into each of the pins (4 in total), so any vag-com tool should work.
Any ideas?
Thanks,
Pradeep
Any ideas?
Thanks,
Pradeep
I build an adapter using a OBDII connector I harvested from the junkyard. A local Audiworlder's VAGCOM software could access my ECU and TCU, but not my airbag controller. In essence, it was no better than the VWTOOL software I have. (my goal was to reset the airbag light.)
I'll be watching this thread with great interest.
Not only will it work flawlessly and allow much more functionality..... They actually support their products very well, and will solve any problem you happen to encounter.
