Climate Control problem
The climate control vents in my 1992 CS100 refuse to work no matter which button I push (defrost, manual controls, or auto) all the air comes from the dash vents also there is no heat with the temperature setting on high.
There were several fault codes in the climate control so I talked the local Audi dealer into clearing them for me. Several of the codes returned.
Fault Codes:
8.7-Temperature Regulator Flap, sporadic block.
11.7-Central Flap, sporadic block
13.5-Footwell/Defroster Flap, static block
15.1-Air Flow Flap Motor Potentiometer, static open
Any help would be greatly appreciated.
Fault Codes:
permenant fault and sporadic an intermittent problem because I have a:
8.5 Temp Reg Flap static block
15.7 Air Flow Flap, sporadic block
The Temp Reg Flap is located in the plenum near on the heater box but is there such a thing as the Air Flow Flap on US/Canadian models?
mattd860
12v V6 Discussion
04-19-2005 02:02 PM
MontcoPaA4
02-04-2005 07:57 AM
msvphoto
Audi 100 / A6 (C4 Platform)
04-30-2003 11:02 AM
