Cougar Problem Re-Visited
Re: Cougar Problem Re-Visited
could be part of the problem...but if the steering is notchy, and works irratically, it is more than likely the rack itself....check the fluid level, and see if it is leaking from the pump area or hoses..if it is low on fluid it will for sure make noises..make sure if you add fluid, it is of OEM specs...
larsenracing
18
03-27-2018 10:42 AM
agentX
10-06-2005 07:13 PM
talicious82973
10-13-2004 06:03 AM
