Cutting stock springs
#13
If not, then there's your reason for the tires and mounts. And the brake line failure can be prevented with longer hoses and/or addition of rubber sleves on the brake lines where the hose meets the fitting.
#16
1. You need to either shorten the spring or lower its lower mounting
2. change the shock stroke proportionately, since it must now move lower, and you dont want it to bottom out and break
3. re align pretty much everything-and it may not entirely get within specs
So you are best to get a fully engineered kit with new struts and springs. All else stays exactly the same. Biggest benefit is lower center of mass
One could simply buy a factory sport setup, btu they cost mroe than aftermarket.
Grant
Grant
jedblack
26
11-29-2011 04:13 AM
scotty11
Audi Original "S" Cars
15
11-11-2006 11:20 AM
2000SForce
9
04-23-2005 01:50 PM
