Directional Vents on my 1995 Audi A-6
I have a 1995 Audi A-6 and I am having trouble with the directional vents. I have the climate control in the car but when I hit the button for the air to go on the floor or on the windshield nothing happens. Why is this happening and what can I do to fix it. I have worked on many parts of Audi's but I have never had to get into the vents so I will need all the help I can get. I would really appreciate it. Thank you.
Does it only direct the air through the dash vents? I've never looked into this area before but I would imagine that the controls for the vents would be vacuum controlled/soleniod controlled. Fuses ok? Was anywork done to it recently?
It only directs air through the dash vents. If it is vaccum/soleniod controlled where or how would I go about checking this? The fuses as far as I can tell are all ok. That was one of my first thoughts too. There has not been any work done to it recently, it is just all of a sudden stopped working.
Any other ideas?
Any other ideas?
<center><img src="http://pictureposter.audiworld.com/40588/vag02cbb.1.jpg"></center><p>I believe that control soleniods and flap is in the between the fire wall and windshield cowling. Check the levers, vac lines and motors there.
Do you have a key for what all these numbers are pointing to? If so that would be great. If not I will try my best to figure it out.
Also will I need to access this from the inside of the car or the outside?
Thank you.
Thank you.
You need to access it from the outside, just behind the firewall. Here is a link to a picture that has partial photo<ul><li><a href="https://forums.audiworld.com/a6100/msgs/11662.phtml">https://forums.audiworld.com/a6100/msgs/11662.phtml</a</li></ul>
Here is the key for the parts, I hope the link works.<ul><li><a href="http://194.87.53.210/audivw/vag6.asp?subm=%CF%EE%E8%F1%EA&btsnr=819-20&cid=154">http://194.87.53.210/audivw/vag6.asp?subm=%CF%EE%E8%F1%EA&btsnr=819-20&cid=154</a</li></ul>
mike beeton
Audi 100 / A6 (C4 Platform)
05-09-2018 05:25 PM
grrttjn
08-01-2002 12:05 AM
grrttjn
07-16-2002 12:59 PM
