easy
i need to replace a few bulbs in my dash, the coolant temp bulb is out, 1/2 of the RPM gauge is out, and the outside temp bulb ( i know u have to solder this one in) i read in the forums that u can get this at radio shack, but could someone tell me all that i need to get ie: size/type of bulb and so on
thanks
thanks
The standard background illumination bulbs are 1.1 watt bulbs (IIRC, there are (9) of these), but you can use a slightly larger wattage bulb, such as 1.2 watt to replace the OEM size. Others here have used 2.0 watts, but I think those are too powerfull as they will draw a lot more current, which may cause other electrical problems. The solder-in bulbs are Radio Shack #272-1092 (#7219) Mirco Lamps, come 2 per package.
ok so you're saying that i need two 1.1(or 1.2) watt bulbs too replace the two that are out in my dash gauges, and for the outside temperature gauge i need the part# 272-1092 solder in bulbs, but this might be a stupid question but what gives them the red color if they're clear bulbs, is there a red screen or something in front of them?
thanks again
thanks again
a part number from wherever(radioshack,Napa ect) i should buy the bulbs for the coolant temp gauge and RPM gauge would be best
thanks
thanks
<a href="https://forums.audiworld.com/a6100/msgs/62403.phtml">Instrument Lamp</a>
The replacement procedure and lamp part numbers are <a href="https://forums.audiworld.com/a6100/msgs/47727.phtml">here</a>.
SpeedyDTP247 CQ+UrS4
15
02-26-2007 07:12 PM
webster
Audi 100 / A6 (C4 Platform)
04-24-2004 05:52 PM
Carped1em
04-23-2004 08:13 AM
wagon_lover
9
03-12-2002 07:48 AM
