engine swap for 1995 audi a6 quattro
how much do you think 2.2 swap will cost? or should i just put in a a6 30 valve with less miles. just considering this cause. i had some issues with my car after i bought it. has 144000 miles on it. think i should just tune it up and replace timing belt? or rebuild engine? JUST looking for something with a little bit more performance
thanks
thanks
Engine work, which I have looked into, just isn't worth the price for these cars.
If you want more power, go with an S6 and mod the turbo to get your desired hp.
how many miles can i expect to get out of the engine if properly maintained? i brought this car about 3 months ago and had to do a little work breaks, tires, then my car over heated and the fan was not coming on. my brother jumped IT SO THE fans work. so i have to get it fixed. he will fixed.
<a href="https://forums.audiworld.com/a6100/msgs/31818.phtml">https://forums.audiworld.com/a6100/msgs/31818.phtml</a>
Also, you can start your reply in the subject line...no need to type "reply".
thanks that information is helpful, will start to work on some of those issues, i know i have to get some work done for suspension as well. luckily my brother is a mechanic. How many miles do you gues have on your a6's
thanks
thanks
