Fault P1101- Ox Sen Low Voltage / Air Leak.(false air) AFC Engine
Anyone have a suggestion as to where to start looking for the cause for this one? Where are the common places for leaks in the system? Or do I just have a bad oxygen sensor?
2. Check for exhaust leak in bank 1 exhaust system before heated O2 sensor (HO2S) -G39-; 3. wiring to O2 sensor faulty or O2 sensor faulty.
If you will by sensors without connectors, it would cost you $80 and the replacement can be done at home. You will save on fuel right away.
BVRN_RKT_94_90
04-20-2004 07:41 PM
