front top strut mount
It's easy. Take the big nut off the part that popped thru the broken mount.
mark the position of the triangular mount with a sharpie, all the way around it.
remove the 3 nuts holding it to the car body.
jack up the car so the strut can be pushed back down into the fender well.
reassemble in the right position as marked.
Doug, have you done yours yet? any good photos?
There are several pages in the FAQ listing good parts suppliers. FWIW, I'd stay away from
Meyle brand suspension parts.
Autohausaz.com has them for $23
I've gotten a few good ones at salvage yards over the years.
So did the failure damage you hood?
Re: There are several pages in the FAQ listing good parts suppliers. FWIW, I'd stay away from
no not yet but I would like to get it change out before it does. The struts where new only a year ago with mounts and everything else . Should I change the bearing there too???
I order the mounts, bumpers and bearing I should be able to get to all of that with out have to take everything apart right???
had this problem after switching to Bilsteins this year...broke 5 mounts since...
never when used stock Boge's. I think not having bump stop(#2) & cup cover(#1) on a Bilstein setup is killing the rubber mounts or the Meyle brand is just 'crap'! Looking for OEM now...even used.
computrtutr
11-04-2005 09:10 AM
Catamount90
07-28-2004 10:17 AM
