Gamma Bose Questions : SAFE on continously and wiring
Hi there.
I am coming from the 100/200/5000/V8 sub forum as I have a 200 20V and a 200 10V.
However, I have a GAMMA BOSE Radio and thinking that it would be the 200 version, by double cheking the part number, it is a proper GAMMA BOSE with part number 4A0 035 192.
It came out of an Audi V8.
Until now, the car had a Gamma CC ( NON BOSE) installed and poppoing sounds were there each time turning on/off or changing stations.
So, the 4 BOSE speakers were sent to BOSE USA for a full refurbishement ( all 4 - 2 front , 2 rears) and they are as new.
Question is first of all, when installing the Gamma BOse, the SAFE will appear and I canīt get it to display "1000" as I think it should. The radio has been kept aside for the last year or so and when connecting it, pressing FM1 and AM simultaneously just wonīt do anything to it.
The radio came with no code, but someone searched the code for me and hand me a 5166 code. Could that be? Arenīt the codes suppose to begin by 0 or 1? Anyhow, that would be my second problem.
The third problem is that there is some re-wiring done, as previous owner seem to have installed additional speakers on the top of the I/C....I believe, that V8 and 200 20V with BOSE had only 4 speakers....
So, could anyne help on how to have the possibility to enter the code and the wiring for the radio?
I believe that middle socket does not have anything pluged, right? As this would only be for the CD changer. IS that right?
Thanks a million
Regards
Thanks a million
Regards
This is what I found on the net as wiring. This is exactly the same as I have on my "new" Gamma BOSE so this would drive me to connect it in the right manner.
Is this everything I need to make it work?
How about the I/C stations information? Where would that come from?
And also, so as I see, speakers connections are only at the third connector where it says LR, RR, LF, RF. Is that correct?
Ben@achtuning
07-09-2003 09:50 PM
Rik
05-29-2002 10:41 AM
PDXA4
12
08-22-2001 01:05 PM
A4BINGO
08-17-2001 10:01 AM
