Gas Leak
96A6Q dripping under front pass seat. Appears to be from around a mounting bracket for the gas line. Anyone ever had this happen? Too cold here to tackle so may have to go to indie along with the previous thread re: the t-stat. When it rains, it pours.
Thanks for any advice.
See how bad the "damage" is and then pull the metal fuel line down away from the body so you can cut the fuel line in half, right at the damage. Or, cut out about 1/2" section of the metal line, either side of the "damage."
Then go buy about 6" of fuel injection rated fuel hose sized to fit over you metal fuel line....probably 1/4" or 5/16" ....and 2 hose clamps.
Spray a little spray lube inside the hose and slip one end onto the metal fuel pipe, slip on both hose clamps, slip the other end onto the other section of fuel pipe, and then tighten down your hose clamps.
Done.....permanent fix.
Thanks so much for the advice. I'll try and get a better look if I can get the mounting bracket off. it's pretty cold here in Buffalo so I may have to take it in as my garage is not heated.
Both had pinhole leaks inside the rubber brackets. Crud builds up in there and corrodes the line. I did the 200 in the driveway in February in Vermont. Not fun!
As austinado16 suggests, cut the fuel line and replace the section but use metal brake line. I found that it was easier to remove the fuel line entirely from the car. Undo the fittings at each end (near fuel tank and in front of the cats). Then pop all of the brackets with a screwdriver and pull the line out. There's a shield by the cats that can be loosened to make access easier.
Measure the total length of the line...end to end. When you replace part of it, the full length has to come out the same. Go to your friendly parts supplier and get a length of replacement metal brake line the same diameter. It doesn't have to be metric. A close inch size works. Also get a couple of compression fittings.
The section I replaced was about 24" long and spanned 2 rubber brackets. I cut the bad part out of the line and carefully bent the replacement to exactly the same shape. Don't make the bends too tight. Now fit the replacement into the line and secure the compression fittings. Measure the line end to end to make sure the total length is right.
Now reinstall and check for leaks. I've done this twice and it makes a good, permanent fix. A new fuel line is expensive.
Mr. Bungle
12-04-2006 10:47 AM
