here is the most frequent quession
I will go for 90K service. What Do I need to do. Here is the list of things I will do:
Timing Belt/Watter Pump, Tensioner
Standard Check up
Oil/Oil FIlter
Serpantine Belt (?)
Brake flush
Thermostat (?)
Do I need to do all these Items?
Did I miss somethong?
I had searched for prev posts. Muhhamad mentioned transmission service and the diffirantial service. What is that? Do I need to do it?
Thanks
Standard Check up
Oil/Oil FIlter
Serpantine Belt (?)
Brake flush
Thermostat (?)
Thanks
While you have it apart, replace the idler roller as well ... the follower is also in there but that's really excessive. I did timing belt, tensioner, idler.
Serpentine belt alone is ok ... the tensioner <i>could</i> go but it's really unlikely, and it wouldn't really cause any damage except the belt (not like a timing belt tensioner which is one of those chain-reaction failures).
Make sure you do the water pump gasket, and the thermostat o-ring, and .... COOLANT FLUSH.
I'd skip the brake flush until you actually replace the brakes, unless the fluid is over 2 years/50k old. It usually stays good for a long time, and when you flush it, it is clean.
Transmission service should be done at a 45k interval ... flush fluid plus replace filter.
Differential fluid flush on quattro models should be done every 45k as well, although I think that's one of the fluids that has a life longer than 45k. Check the seal while you're at that... and hope it isn't leaking!
ECS Tuning-Audi
30v V6 Discussion
04-28-2014 06:16 AM
ECS Tuning-Audi
02-28-2014 12:32 PM
musantemike
01-12-2013 10:17 AM
jdubs914
9
02-01-2012 09:09 PM
