Holy s**t flushing the heater core is a bitch!
Old 01-27-2008, 01:19 PM
RedDragoN750's Avatar
Default Holy s**t flushing the heater core is a bitch!
I understand that I need to remove the heater hose going in and out of the heater, but this is easier said than done. Very tight space. I can't even really get in there to pull the hoses. Anyone have a small asian girl they can loan me? (now thinks dirty thoughts too
Old 01-27-2008, 01:47 PM
DaveInSaltLake's Avatar
can you get to the other ends of those heater hoses?
Old 01-27-2008, 02:20 PM
austinado16's Avatar
Default This is where needle-nose pliers and WD-40(or similar) come in handy.
Loosen the hose clamps and spray PB Blaster, Liquid Wrench or WD-40 where the hose fits onto the fittings.
Now grab the hose with a pair of needle-nose and begin gently rocking the hose side to side by twisting the needle-nose. As you twist and the hose starts to move on the fitting, pull.
Add more penetrant as needed. On really difficult houses, use a strait bladed screwdriver to pick up the end of the hose at the fitting and work the blade around the end of the hose between the fitting and hose, adding penetrant as you progress.
The hose will come right off without damaging anything.
Old 01-27-2008, 02:28 PM
But how to deal with the hose with the bleeder and valve in it?
Old 01-27-2008, 02:30 PM
Default pull the silver clamp holding the air box down. that'll give you clearance to pull that little
section of hose.
Old 01-27-2008, 02:34 PM
Default Or just remove the hose from the heater valve and leave the valve and bleed hose attached.
Or, loosen the clamp where the bleed hose attaches to the heater core fitting, remove the philips screw that holds the heater valve to the side of the heater box, and then grab the vavle and use it as leverage to pull both it and the bleed hose off the heater core.
See.....this is easy.
Old 01-27-2008, 03:11 PM
TTurntable's Avatar
Default need to do this also. will flushing the whole system get the core flushed or
do you need to flush the core also. any one have step by step for the core??
Old 01-27-2008, 03:14 PM
Default The vacuum actuated heater valve may keep you from flushing the heater core
As far as step-by-step goes, you're reading it....
Pop the hoses off as we are discussing, slip on a couple of hoses of your own, and then use a garden hose with a pistol grip type spray nozzle to flush the core in both directions.
Old 01-28-2008, 05:27 AM
TTurntable's Avatar
thanks, was thinking that was the way to do it.
bnam
12v V6 Discussion
01-31-2005 06:29 AM
UrSoccer_mobileĀ®
Audi Original "S" Cars
09-02-2004 11:33 AM
doo
09-03-2003 04:44 PM
Quick Reply: Holy s**t flushing the heater core is a bitch!
